Scratch Build – In Progress Pi-Amp Bi-Amp (Update - Completed!)
Discussion in 'Project Logs' started by ptah, 28 Feb 2011.
  1. ptah
    ptah What's a Dremel?
    15 Feb 2011
    Pi-Amp Bi-Amp Completed!
    I've had questions about using class D amplifiers. My preference is to drive large speakers in stereo mode with lots of power using an audiophile grade amplifier.
    Installed the main board as shown below. It is a GA-MA78GM-S2H w/ a AMD 64 X2 4000, not state of the art but it has decent on board sound and video. I did take care to ensure that this layout will handle a large video card (there is sufficient clearance between the drive head and the main board).
    Installed one Western Digital 1 TB, one Samsung 1.5 TB HDD and a Sony DVD R/W into the drive head.
    Installed the drive head to the controls panel - good fit. The drive head is locked to the controls panel with three machine screws. Also installed the modular power supply.
    I wish that main 24 pin PC power cable were shorter! I've seen how some mods in this forum re-head the PC power supply cables. I will look into that.
    Fitted the chassis cover -
    The rear panel is clean. I elected to pick up line in for the amps off internal pins on the main board rather than jacking into rear the panel.
    And that's how I built the Pi-Amp Bi-Amp! Thanks for the interest and great feedback!
    Now if you'll excuse me I'll be listening to some very loud Radiohead.
  2. forart.eu
    forart.eu What's a Dremel?
    11 Mar 2011
    Ehm, well there are Class-D solutions for your needs:
    http://www.aliexpress.com/fm-store/...AMP-MODULE-GLOBAL-POWER-SUPPLY-PRO-AUDIO.html
    BTW, now an integrated high-quality DAC would be great:
    j4cDAC: a new open-source DAC project
    Open Source/Freeware Budget USB DAC
    Open source USB 192kHz/24bit audio codec
    Audio and Control Interface for Amateur Radio SDR and Audiophile USB-DAC
    Open source USB audio class 2 DAC designs
    Open Source DAC R&D Project
    Hope that inspires !!!
