A/V Pink screen of death?
Discussion in 'Tech Support' started by eVoPhantom, 24 Apr 2012.
  1. eVoPhantom
    eVoPhantom What's a Dremel?
    21 Jul 2010
    Hi all,
    I have occasionally had a problem with the screen turning pink and fuzzy (like old TV snowy interference). This has also co-incided with the pc freezing and only working after a good old fashioned reset. The most recent time this happened it actually returned to normal and begun functioning after probably 3-5 seconds on freezing and turning pink..... Any ideas?
    Specs are as follows
    P67 Sabretooth
    i5 2500k (OC'd)
    8GB Corsair ram(2x 4gb sticks 1600)
    1GB MSI GTX 560ti (not overclocked over the factory based OC)
    600 Watt corsair PSU
    Thanks
    EDIT: should also add win 7 64bit
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Sounds like a gpu issue. Have you stress tested it with Furmark?
  3. eVoPhantom
    21 Jul 2010
    That was my first thought as well, but it seems to happen only when doing non intensive work. It has happened several times when only browsing the web, having not done anything heavy immediatly prior.
    I have tested with heaven recently for a reasonable period of time with no problem but I shall also test furmark later when I get in.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    have you checked the cable from pc to screen? try wiggling near the plugs
  5. GoodBytes
    20 Jan 2007
    Web browsers of today, uses your GPU.. Windows desktop (Aero) uses the GPU as well.
  6. Shirty
    18 Apr 1982
    Would have been my first suggestion, but it would surprise me if that caused the computer to lock up. :eeek:
    What driver are you using for the graphics card? Have a peep in here.
    If you have a spare GPU to test with I would suggest that in the first instance, although because the problem is intermittent it will be difficult to replicate. Anything in event viewer that might give a clue?
    eVoPhantom likes this.
  7. eVoPhantom
    21 Jul 2010
    Thanks for the link, I had been having the problems with black screen and the error message relating to drivers. I rectified that with a clean install of the drivers (not sure which version will check when home). I have not had the black screen error for a good few months so wrote that off as a solved issue. However I have had the pink screen 3 maybe 4 times this year, so not a regular issue but an annoying one.
  8. Shirty
    18 Apr 1982
    Definitely worth trying the roll-back/beta route to see if it helps.
  9. TraumaticHug
    TraumaticHug What's a Dremel?
    23 Apr 2011
    Hey, I have the same issue and the same card, but quickly found this possible solution.
    It seems that nvidia's 290 drivers don't like the 560 ti. I'm trying the 301.24 Beta drivers.. ..seem okay so far.
