Plane on a Conveyor - IT TOOK OFF!
Discussion in 'General' started by will., 13 Dec 2007.
Will the plane fly
  1. Yay
    89 vote(s)
    72.4%
  2. Nay
    34 vote(s)
    27.6%
  1. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Well i wouldn't say any plane, but some planes, particularly those with large wing span area to weight ratios, can lift in extremely windy conditions, like a smallish cargo plane, or some small planes or ultralights, maybe even WWII bombers - no ammo, guns, bombs (empty) may lift a little.
    When the wind speed is half decent, the few that have a high thrust to weight ratio, may lift a little.
    But if they are on a conveyor belt, then there's obviously no doubt what will happen, as covered in this short 14 page thread :thumb:
  2. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I have some words for people to digest: Flying Concrete Fish Paper
    Discuss.
  3. mvagusta
    24 Dec 2006
    Well, if you take the speed of light into account, and the resulting heat from the bearings, it's more like "flying charcoal fish finger" but when P = O, well then, you just have frozen fish fingers, but that's just silly :lol:
  4. Nexxo
    23 Oct 2001
    True, but I think this is another example of a Zeno's paradox. Zeno's equation would suggest that Achilles can never catch up with the tortoise, but common sense and experience tells us he would. The equation looks at it the wrong way so doesn't work.
    Similarly, experience and (thought) experiment tells us the plane will take off. It is impossible to make the conveyor belt match wheel speed because wheel speed is a sum of conveyor belt speed and plane forward speed. That doesn't mean the plane can't take off; it means that the equation is impossible.
  5. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    No point at all - but did lack of a point ever stop such threads?
  6. Mord
    Mord What's a Dremel?
    7 Mar 2004
    Why don't they use conveyer belts on aircraft carriers to shorten the length of the runway?
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Because it's inefficient, expensive and not very durable. It would require a lot of energy to get that conveyor up to speed fast enough. (It can't be running when the plane is driving onto it).
    When you think about it, a conveyor would probably weigh a lot more than a plane, and will have to get up to the same speed.
    They do have a similar systems on aircraft carriers, though. It's a catapult that attaches to the front wheel of the plane. It's powered by steam from a nuclear reactor, though. (and are made for a lot smaller planes than a passenger jet)
  8. Nexxo
    23 Oct 2001
    For the same reason planes can take off from conveyor belts moving in the opposite direction.
    The plane's movement is totally independent from the belt.
  9. Smilodon
    25 Mar 2003
    Nexxo: It would work if they applied the brakes while on the conveyor. It would probably kill both the tires and the brakes, though. I'm not sure the gear would be able to handle the load either.
  10. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    the launcher on a carrier has about 2,000,000 horse power. not to mention when they land they snag a cable with a hook and that stops them pretty quick.
  11. willyolio
    willyolio What's a Dremel?
    17 Feb 2007
    because catapults work better.
  12. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Yeah, totally. It is a bit of a paradox. Though the question I was examining basically stated that equation, so based on that (rather contrived scenario), the plane can't take off.
  13. Jipa
    5 Feb 2004
    That just seems to be roughly as close to the original question as "does a boat take off from a conveyor belt?".
  14. Tomm
    12 Apr 2004
    Boats go in the water.
  15. mvagusta
    24 Dec 2006
    The conveyor belt DOES NOT shorten the length of the required runway - if anything, when using a conveyor belt, the additional friction from the wheels might mean another few cm of runway is required, but a nice headwind can easily mean a few meteres less of runway is needed on a conveyor belt, and having a light pilot & and empty plane can mean another meter or so less runway required.... etc... Conveyors are the same as when taking off on land, just a few extra cm's from the friction from the wheels... :duh:
    Catapaults are used to directly force the heavy jets at the required take off speed, and are very different to the conveyor belt situation, as they are DIRECTLY attached to the plane via the front suspension, not via the low friction of the wheel bearings in the opposite direction!!!
    I guess this thread is at the stage where the same old discussions have been done to death 10 or 20 times, so now we are anal probing the myth from every concievable angle, using whatever we can find to shove up there :blah:
  16. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Just watched this on you tube, it looks dodgey, how many feet did the plane move until it was airborne? Because it just looked like its forward speed exceeded that of the conveyor, if that wasn't the case why did it move past the cones? I thought it was sposed to just take straight off? >_<
  17. mvagusta
    24 Dec 2006
  18. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    It would, but next there is no feasible way to perfectly make the plane go straight forward at the exact same speed the conveyor moves backwards. If you were to make it that way, it would still take off.
  19. Oclocker
    21 Jun 2001
    put a hovercraft on the belt & it flies! or does it?
  20. Tomm
    12 Apr 2004
    It would get in the way, thus stopping the plane taking off? :p
