Hi all, having a deeply frustrating problem with my comp atm. Whenever I play CS:Source after about 5 mins i get a connection error and my connection dies, everyone else in the house is fine though its just my computer. It happened earlier when i was downloading too, although that was after it had completed. Any ideas? its just really annoying. If i disable the connection and then enable it the problem is solved, internet browsing doesnt cut it off or anything. I uninstalled steam and reinstalled that in a new folder on a different hdd, same problem. Hmmm cant think of any more info...so what do you make of it? Thanks
you posted in the wrong section mate, try tech support?? a mod will probably move it soon. Done - Wonka
How are you connected to the network, wireless per chance, if thats the case it could well be down to your router.
