Windows Playing old games on a modern pc
Discussion in 'Gaming' started by johnnyboy700, 7 Aug 2008.
  1. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    Hi Folks
    Here's a query for you to pick over, I know that some old games simply can't be played on modern pc's and OS because they were designed on and made for much slower pc's or they were made on different versions of Windows.
    One example that I've had a problem with is the original Thief (Gold version), I'm running XP with SP3 and when I try to load the game I get a warning box saying the game cannot run on Windows NT and aborts the load.
    I know there are ways around some problems with programmes such as Scumm and dosbox or you might even get specific versions of certain classic games that have been tweaked to run on XP and Vista (X-Com!!) but I'm wondering is there any hope for some old classics that aren't so well looked after.
    There are two games that I'm particularly missing playing, they are Terra Nova (an absolute gem of an old school game by Looking Glass, you know how good they were!) and Blade Runner - perhaps the best movie based game ever. I have seen mentions of utility programmes that will let you run old games on today's pc's but anytime I go to search for them I can never find them. So my question is does anyone out there in Bit-Tech land know of any such programmes or do I simply leave my old favourite and truly brilliant games as a fond distant memory?
    :thumb:
  2. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    I fully recommend virtual PC from microsoft, I use it for all my old games that cause me fuss and bother. VPC is free , or used to be, but you'll need a copy of an old OS though 98 should do the trick.
  3. itazura
    itazura PAWAA GURABU DAISUKI, YABAI DESU YO
    10 Jun 2008
    i've alternated between running another box with windows 98 and using dosbox on my main machine. both seem to do the trick, although the win 98 method is much more satisfying imo!
  4. Daveofthedead
    Daveofthedead What's a Dremel?
    29 Dec 2007
    i still have a pc ruining win 95 thats my way around it :p
  5. Amon
    Amon inch-perfect
    1 Jun 2007
    Even with some of these virtual domain programs, you might run into audio issues from the lack of a legacy Sound Blaster 16/32AWE or whatever.
  6. cbwestrunner
    cbwestrunner What's a Dremel?
    4 Aug 2008
    well, you can always pick up a piece of junk for your older games, a win 95/98 machine shouldn't be hard to fine. I figured that you might've done this, but have you even installed the game and then adjusted the properties on the executable to run the program in compatibility mode for different OSs? that's how i could all my old DOS and win 95 games to run in XP... never ran into any problems
  7. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    What was that new site BT reported on a while ago? The digital distribution site...
    It's going up in September, I believe, and it'll have older games which have been tweaked/updated to work with Vista and XP.
  8. caffin999
    caffin999 Bit of a noob, but learning quickly
    20 Jun 2008
    good old games! www.gog.com
    they are updating old classic games to run on newer computers. going to cost 5 dollars each. or was it 10 dollars!?!
  9. jrr
    jrr What's a Dremel?
    18 Aug 2008
    You can play many old games on a modern machine via dosbox. They have a compatibility list to help you out.
    Though I haven't turned it on in years, I keep an old pentium 166 with a creative labs card and win98 around for this reason =]
