Graphics Playing Skyrim with a GTX-560 TI
Discussion in 'Hardware' started by Cus_de_Sparta65, 1 Dec 2011.
  1. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    I want to know if I stuck a GTX-560 TI in my sons rig would it run Skyrim on decent settings. He has a Samsung 24" Full HD monitor as well as a Samsung 32" LCD Full HD-TV that has PC Input.
    I am thinking ok for the 24" but a big no-no for the 32" TV!
    Any advice welcome, thanks
    Cus
    David likes this.
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    It wouldn't matter as if both screens are full HD then they will have the same resolution (1920 x 1080).
    One thing I would say is if you use the TV as the screen then use HDMI as the TV's VGA input may not support the TV's native resolution.
  3. Pookeyhead
    30 Jan 2004
    Its all about resolution. Your GPU has no idea how physically big the TV is. The resolution is the same on both... 1920x1080.
  4. Instagib
    Instagib Minimodder
    12 Mar 2010
    A 560Ti would play Skyrim pretty well at 1080p -everything on high, if not v.high. I've no figures to hand, but I don't think Skyrim is massively demanding.
  5. McDuff32
    McDuff32 Minimodder
    5 Aug 2011
    I have skyrim and it works fine on max settings with a 560ti.
  6. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    A 560 should be fine. I play it with my 460 on the same resolution with a 2nd monitor displaying various things. Even with an over clock on my 460 a 560 will be better. It runs very well for me.
  7. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    if a 360 can run it a 560ti will destroy it
  8. Zener Diode
    Zener Diode User Title
    13 Sep 2009
    I think Skyrim is quite CPU dependent (from what I've heard)
  9. kenco_uk
    28 Nov 2003
    The 32" TV would probably let it run better tbh as it'd be lower resolution if it's a 720p (HD Ready) set. I'd assume the monitor would be 1920x1080 or 1920x1200 whereas the 32" would be 1366x768 or if it is Full HD - 1920x1080. However, a 560ti would be ample to run Skyrim.
    On my rig at 1920x1200 with everything on as high as it'll go, I get (according to fraps) at least 30fps. In buildings it can hit nearly 50fps at times.
  10. Cus_de_Sparta65
    24 Apr 2009
    Thank you everyone :thumb:
  11. Pookeyhead
    30 Jan 2004
    He said it's a full HD 32".. so it's the same res as the monitor
  12. Tangster
    23 May 2009
    I generally hit 50-60 fps with an overclocked GTX460, I've maxed everything but use 4xAA and 8xAF with FXAA off.
    A GTX560ti should easily run it.
  13. Bede
    Bede Minimodder
    30 Sep 2007
    Skyrim will have frame rate drops on the 560ti in some areas - misty bits seem particularly badly optimised. However on the whole it's perfectly capable of running anything that can be currently thrown at it, skyrim is the first game I've noticed where the fps dropped below ~30.
  14. loftie
    loftie Multimodder
    14 Feb 2009
    +1
  15. Tangster
    23 May 2009
    I'd assume if the OP is going to use a 560ti the PC he's dropping it into will have a fast enough processor that it isn't bottlenecked. That should be sufficient.
  16. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    It will play it on ultra, my 8800gt is running on high at 1400x900
  17. Cus_de_Sparta65
    24 Apr 2009
    He has a AMD Phenom II X4 Black Edition 3.2 GHz just now with a V8 HSF.
  18. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    My laptop can handle Skyrim with a 540v @1366x768 on medium, which I think is great considering I didn't buy it with gamin in mind
