Please help answer this questions.
Discussion in 'Hardware' started by Blast, 9 Jun 2004.
  1. Blast
    Blast What's a Dremel?
    9 Jul 2003
    I need help answering these Q's for a school class.
    When you install a CPU in some motherboards, usually some jumpers need to be changed to give the computer specific information about the CPU. I am looking for three things (hint: One of them is the voltage).
    What is the difference between what CPU’s a socket 7 motherboard will support versus what a slot1 motherboard will support?
    What is the purpose of disk overlay software such as EZ Bios or Ontrack Disk Manager?
    What is the partition limit in fat 16 file system?
    In a retail computer repair environment, what other file systems would you expect to encounter?
    How would you preserve users ISP logon info if you had to reformat a hard drive and reload the operating system?
    What is the difference between 56k x2 modem and kflex?
    What is the current 56k standard?
    What is the purpose of the windows registry?
    Why would you edit the windows registry?
    What is a cab file?
    What is direct X?
    What are you doing when you map a network drive?
    What is the difference between a network switch and a router?
    What are the situations where it would be better to use a hardware firewall versus a software firewall?
    What is an example of a Well Known Port?
    What is a subnet mask?
  2. Carbon
    Carbon Banned
    8 Jan 2003
    Dont want much :rolleyes:
    The current 56k standard is as follows
    BIN IT...ITS TOOOOO SLOWWW
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    TBH m8, :search: google is your new best friend.
    If you dont have any luck, I'll poke through google laters, tiredness and drunkness dependant of course.
  4. Mecha_Mindslayer
    Mecha_Mindslayer Banned
    23 May 2004
    Voltage
    Fsb
    Multiplier? :worried:
  5. Guest-2867
    Guest-2867 Guest
    Isn't the whole point of homework to do some research and learn a bit? your not supposed to ask ppl the answers! use google or something ! :hehe:
  6. nimbu
    nimbu Multimodder
    28 Nov 2002
