Please Help..
Discussion in 'Hardware' started by Clone, 21 Jul 2002.
  1. Clone
    Clone What's a Dremel?
    23 Nov 2001
    Ok here’s the problem
    Every now and again my PC Locks and the sounds is stuck on what note it was playing at the time.
    This happens when playing games and watching movies on various different players, (happens most on watching movies) Since this problem has been with me, I have clean installed XP Home and tried moving the cards around etc, but to no avail.
    The only thing that helps a bit was to put the vcore up to 1.775 it still locks but no so often.
    Any Ideas?
    PC Spec
    Abit KG7 Lite Mobo
    2x 256 DDR 2100 Crucial
    Athlon XP 1900+
    Creative Geforce 4 TI440
    Sonic Fury Soundcard
    3com EtherLink 10/100 TX (3c905bTX)
    SMC EtherLink EZ Card (SMC1255TX)
  2. George
    George Bah
    14 May 2002
    CPU temp?
    is this a new system, or has it just started happening recently?
    .icecube
  3. George
    George Bah
    14 May 2002
    btw, in your sig, should be TI4400. :D
    .icecube
  4. Loz
    Loz Blah Blah
    16 Apr 2002
    Or an MX440 ;)
    ~Sepherus
  5. Adam
    Adam Minimodder
    26 Jan 2002
    Have you got the latest detonators?
    Also what temps are you getting?
  6. Clone
    23 Nov 2001
    I have the 29.42 Dets and the sys temps are 40 idle 46 load
    The system is 8 months old, and still did the same with a old Creative Geforce 2 GTS.
    and it's a TI4400 ;)
  7. Adam
    Adam Minimodder
    26 Jan 2002
    Well I'm almost out of ideas. It could be a duff board or chip, try upping the voltage some more, just keep an eye on the temps. Also have you tried removing the soundcard?
