Modding Plexi glueing with Epoxy question
Discussion in 'Modding' started by Eran, 28 May 2005.
  1. Eran
    Eran What's a Dremel?
    6 Nov 2004
    Is this the right thing to glue my plexi case with ?
  2. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    I've tried everything and what works best is weld-on #16.I was amazed at how strong it sticks and stayed very clear between the pieces.I even had pieces held by the side angles just side by side but at a 120° angle of course i had to apply several coats till i almost fill the gap but i had to apply force to crack it. Epoxy especially that one is messy and dosn't stick very well. It cracks almost just looking at it :eyebrow:
    You can get it here. Depending on where you are, the delivery is a bit slow.Took me 8 days to get it to canada originated from San Diego
    http://www.rplastics.com/plac.html
  3. Eran
    6 Nov 2004
    I live in Israel so I don't think it's the best for me...
    P.S : do you know how can i make a plexiglass white instead of clear?
  4. Kobalt
    26 Aug 2003
    The cheapest way is light sanding but it takes time and effort or if you can get a stuff called glass frost that works very well.
    Btw, if you go to the weld-on site, they probably will give you a place closer to you, they sell world wide :thumb:
  5. Eran
    6 Nov 2004
    can't i just buy a white plexiglass ?
  6. Kobalt
    26 Aug 2003
    I asked weld-on themselves after i ordered mine from San Diego,and they gave me places here in canada sorry i've lost the link but here's the return address i got with the answer so i guess you could use it to ask your Q :D
    info@ipscorp.com
  7. Kobalt
    26 Aug 2003
    Sure but white plexi looks so hospitaly lol :hehe:
  8. Eran
    6 Nov 2004
    What can you suggest me for my HTPC ? It should look elegant.
    (I got no dremel)
  9. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    Epoxy is really good for encasing and filling, but it's not very good for gluing on smooth surfaces.
  10. Eran
    6 Nov 2004
    So can you suggest me a material that will look elegant and not hard to use ?
    I want to order exact sizes and just connect with glue or pins or nits
  11. Kobalt
    26 Aug 2003
  12. Eran
    6 Nov 2004
    Im having a really small case, and i think it will interrupt the mobo :\
