Case Mod - In Progress Plexy HTPC [FINISHED]
Discussion in 'Project Logs' started by Razarach, 29 Jul 2011.
  1. Razarach
    Razarach Minimodder
    28 Jan 2009
    Hi guys!
    Here is my new project. Main idea is build small, stylish case with good airflow.
    So i decide to use plexiglas for this build. I will use pieces of plexy 1 cm width and 0.5mm thickness.
    Here is some concept pictures.
  2. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Nice design, what's up with the SATA cable?
  3. Razarach
    Razarach Minimodder
    28 Jan 2009
    I just sleeved cable so i stick it here for the picturing
  4. Razarach
    Razarach Minimodder
    28 Jan 2009
    Hey guys. Here is some update and new photos.
    After measuring i drill holes in plexy pieces for case side panels.
    [​IMG] [​IMG]
    After that i drill holes in base plexy for side panels holders.
    [​IMG][​IMG]
    First i try if it fits....
    [​IMG] [​IMG]
    And then i assemble whole case to see how this looks like.
    [​IMG] [​IMG] [​IMG]
    This is all for today. :dremel:
  5. NEM3S1S
    NEM3S1S What's a Dremel?
    18 Jul 2011
    looks realy nice, looking forward to more ;)
  6. Razarach
    Razarach Minimodder
    28 Jan 2009
    Hi guys! Here is some little update after vacation :D
    After cutting plexiglass i got rough surface...
    After sanding i have perfect smooth surface.
    I got 24pin extension cable so i use aquamarine blue cable sleeve and got this..
    Next thing to do is assemble hdd holder and case is done...
  7. Razarach
    Razarach Minimodder
    28 Jan 2009
    Hey guys, new update is here :p
    First I cut rubber for hdd to reduce vibrations.
    Then i cut plexy piece for hdd holder.
    And then i cut cover to hide hdd electronic.
    I assemble all parts together to see how it looks.
  8. Razarach
    Razarach Minimodder
    28 Jan 2009
    Done! :D
  9. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Its a nice concept, could be nice to see it up and running.
  10. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    How exactly are you going to power it?
    I mean I love the design concept, but I think that sticking it onto an outboard PSU with the nest of wires that would bring would ruin how beautifully clean it looks.
    Great build otherwise
  11. Razarach
    Razarach Minimodder
    28 Jan 2009
    Tnx guys.
    Up and running.....
  12. Lance
    Lance Ender of discussions.
    6 May 2010
    Really great build I love the idea.
    BUT
    Just a question. Why not make a similar looking case for the PSU and so a sort of hi-fi style stack?
  13. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Where exactly is the power button? :p
    Looks very pretty. I like it a lot.
  14. Moddingboy
    Moddingboy What's a Dremel?
    19 Jul 2011
    Looking good :thumb: Congrats!
  15. Razarach
    Razarach Minimodder
    28 Jan 2009
    @Lance; great idea, i will build some more stuff when i catch some time.
    @Zinfandel; power button is on back side, under motherboard. :D
    @Moddingboy; tnx m8
  16. dream1
    dream1 What's a Dremel?
    26 Feb 2011
  17. dream1
    26 Feb 2011
  18. Razarach
    Razarach Minimodder
    28 Jan 2009
    I dont know, for now i will use regular psu. Maybe some day i will buy something smaller.
