Other Plumbing question, leaking shower tap
Discussion in 'General' started by legoman, 29 Aug 2023.
  1. legoman
    legoman breaker of things
    28 Feb 2010
  2. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I'd just try PTFE tape first, the simplest solution is usually the best with plumbing I find!
    adidan and Goatee like this.
  3. legoman
    28 Feb 2010
    I'll give it a whirl, next job is getting the cartridge out, thankfully its after the taps so no need to turn off the water.
  4. hughwi
    hughwi Minimodder
    23 Dec 2003
    To be honest, if you are going through the whole hassle of disassembling it - it probably wouldnt hurt to replace the cartridge anyway if you are in a hardwater area.
    It might just be the rubber washer has given up on life, you can usually just reverse them or replace them for new ones. - Should be a standard size.
  5. Krikkit
    21 Jan 2003
    Was just about to suggest it - cartridge will be the issue, skip to the end and replace it, don't bother trying to bodge with PTFE, it can just cause more issues than it solves tbh. :)
  6. legoman
    28 Feb 2010
    Yeah just trying to work out what cartridge it is
  7. Krikkit
    21 Jan 2003
    Unless it's a really crappy one it'll be pretty well marked in my experience, I actually found Screwfix have a really good range of cartridges - it sounds daft but I wasn't expecting them to, as their stock depth isn't usually that good.
  8. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    My usual routine for diy parts is, screwfix - toolstation, Wickes - travis Perkins. If they don’t have it, then dreaded eBay or AliExpress.
