Port Forwarding
Discussion in 'Tech Support' started by chiper136, 23 Sep 2008.
  1. chiper136
    chiper136 What's a Dremel?
    15 May 2007
    I have been trying to set up my Netgear wireless router to allow port forwarding so I can play COD4 with a list of more than 10 servers.
    My problem is that I can't get into my router setting via http://192.168.1.1/ or http://192.168.0.1/ because it won't accept my username or password. I have now reset the router 5 times, each time i get taken to a red screen where I'm asked to put in a new SSID, a key reminder and a password, but no matter what I put in them, when it come to accessing http://192.168.1.1/ it still won't let me in.
    Netgear support seem to think if I reset the router enough time it might somehow work for me but I thought maybe some one here might know what the hell I'm doing wrong, or if there is a way around it.
    :wallbash:
    Im using Vista 64bit and a Netgeat Wireless router (WGR614v9). My internet is provided by Virgin Media.
  2. spoon.uk
    spoon.uk Frag Me Bitch!
    1 Sep 2008
    For how long you're keep holding the reset button?
  3. chiper136
    15 May 2007
    The Netgear site tells me to hold the reset button, turn off the power and then, with the button still pressed, turn it back on and hold it for 20 seconds. Thats what I have been doing and as far as i know it been working as each time Vista has to try and find the network again.
  4. Letapz
    Letapz What's a Dremel?
    24 Sep 2008
    Did you try logging in without a password? On Dlink routers default is admin (username) with no password. Not sure Netgear though.
  5. chiper136
    15 May 2007
    I've tried everything conceivable now. It just doesn't like my user name or password, no matter how much I reset it or anything. Looks like I will just have to fork out for anotehr router or wait for my landline so i can call the tech support at virgin media.
  6. chiper136
    15 May 2007
    Found it.
    If you use virgin media
    User : virgin
    Password: password
    2 days of frustration and the answer was less than a meter from me on the bottom of the dam router:duh:
  7. Letapz
    24 Sep 2008
    Well I am glad you found it. :clap:
    I know how frustrating it can be believe me.
