Windows Portal orientation issues
Discussion in 'Software' started by Thatguy119, 13 May 2010.
  1. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    Basically I decided to download steam and portal since its free. Downloaded fine, went to boot up portal and realised it had orientated itself 90 degrees anticlockwise, so what should be the top was in fact at the right hand side of the screen. I tried flipping it by pressing alt gr then arrows, but that only effected windows, not portal. Does anybody have any ideas?
  2. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
    What graphics card do you have? Is the problem apparent in any other games?
  3. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
  4. Thatguy119
    17 Nov 2008
    Nope, its the same problem though. I will try playing it not full screen.
  5. SouperAndy
    16 Feb 2009
    Very weird issue (I've never heard of it before, ever).
    I think what the guys on the Steam forum are saying is to start at minimum res in windowed mode and then 'step up' the res to your required level. Then you switch to full screen and see what happens?!
    Cheers,
    SouperAndy :worried:
  6. Thatguy119
    17 Nov 2008
    Im running it on a laptop, decent spec but nothing amazing, only reason I downloaded was that it was free and the specs looked quite friendly.
