Modding Positions for radiator in midi case?
Discussion in 'Modding' started by -DeMoN-, 4 Jun 2004.
  1. -DeMoN-
    -DeMoN- What's a Dremel?
    21 May 2004
    Im new here :S so hello ppl...
    Ne way, i was wondering if it were ok to put a radiator on the bottom of your case ( providing your case had some feet to get some lift ) sucking air from the ground... is this ok?
    Ofcourse you would HAVE to have dust filters, which may get clogged after a while.. but what are all your thoughts?
    And also, is it ever possible to put one of those Dual 120mm radiators with pump and reservoir with pipe and all that crap into a midi tower case all nealty?
    Heres one of those radiators if ya dont know wat it looks like:
    http://www.pccasegear.com.au/prod656.htm
    And heres a few more questions :p
    With the hardcano 12, can you put the temperature sensors under water? and is that practical?
    How much difference in noise does a water cooling system compare to one with fans?
    I think that'd be all...for now ;)
    Bye for now!
  2. -DeMoN-
    21 May 2004
    Ummm... reply?
  3. Nexxo
    23 Oct 2001
    Sure you can fit it in. Just plan carefully, and resign yourself to the fact that you may have to make do with as few as four 5.25" bays for all your drive needs. Which, if you plan it right, is more than enough.
    See project Metaversa in the project logs. It's not got a BIX2 (only a BIX), but it has got dual CPUs.
