Windows Possible to allow/block certain ports for specific multiple NICs in Windows 8.1?
Discussion in 'Software' started by Bungletron, 18 Mar 2015.
  1. Bungletron
    Bungletron Minimodder
    25 May 2010
    Hi
    I am running Windows 8.1 virtual machine that has 2 NICs, does anyone know if I can configure the OS to block all ports except RDP on one nic (then block RDP on the other)?
  2. Krazeh
    Krazeh Minimodder
    12 Aug 2003
    Have you taken a look at the windows firewall?
  3. Bungletron
    25 May 2010
    yes, I can certainly block/allow in there, but I did not see options to specify the individual NICs.
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    What is it you are trying to do with a setup like that? Maybe there is a better way to do it.
    this got some good stuff too http://www.ohmancorp.com/refwin-advfirewall.asp
    Essentially I don't think you can do it - but you can nearly do it if you have one set as "work network" and one as "public network" but I don't think the control is granular enough for what you want.
  5. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Sorry if I havn't read the post right, but can't you just set static IP addresses on each Nic and block/allow the relevant ports on the router?
  6. Bungletron
    25 May 2010
    I had seen that, it appeared to be a fudge and I had hoped to avoid it.
    Not a bad idea, it is on virtualbox so I will see if the setting allow it, cheers!
