Windows Possible virus? iexplore?
Discussion in 'Software' started by Black Tiger, 24 Aug 2011.
  1. Black Tiger
    Black Tiger Chineapple Punks
    7 Jun 2011
    hey BT'ers having an issue with my computer
    for the past few days my mouse curser has been constantly flicking up the "busy" circle every 1-2seconds
    can't seem to work out why it's doing it tho, ive tried limiting all my start-up apps through msconfig and no matter what it still does it.
    I've also noticed in task manager that iexplorer is always running 2 processes, and eating up 7-10% CPU and 20,000-30,000k of ram, now i dont use internet explorer, always use firefox or chrome.
    Also had a problem with svchost.exe eating around 15% cpu, and it was linked to windefend service, not having a problem with that as we speak tho, and havent got time to restart my pc to see if it happens again tho.
    All this sounds like some sort of virus/malware/adware to me, ive done a full scan with AVG and it hasn't found anything.
    has anyone got any ideas? or know of some software i should use?
    thanks alot
    BLACK-TiGER
  2. Houndofhell
    Houndofhell One Particle to Rule Them All
    9 Jul 2009
    Have you heard of MalwareBytes? Visit their website download their free software, give it a run and see if it comes up with anything.
    EDIT: If for whatever reason when you run malwarebytes and it fails to scan or won't start then you've almost certainly got a virus/malware, there are guides online about how to rename all malwarebytes main files, so it can side-step viruses stopping it.
  3. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    Are the same processes still running after a reboot?
  4. jossi007
    jossi007 What's a Dremel?
    26 Sep 2011
    1. Click Ctrl-Alt-Del and kill the iexplore processes. If it stops, than you know that that's the problem.
    2. Restart into safe mode and try a system restore to a date before the problem started.
    3. try malwarebytes anti malware in safe mode.
    Hope this helps
  5. short1uk
    short1uk Minimodder
    20 Sep 2011
    I saw this the other day on a machine. Even though IE wasnt open 2 instances of it where running in the back ground. After a while a message would pop up with an error saying IE couldnt connect to the site the machine wanted. Even though no IE had been opened on the machine (Well not by the user anyway)
    Tried surfing on the machine and it kept redirecting to other sites...... virus scan failed at 2% every time too. Ended up reinstalling the machine as they needed the machine back asap.
    Defo run Malwarebytes the full scan which can take some time so grab a drink and just wait for it to finish. Let us know how you get on.
    Catherine
  6. windy
    windy What's a Dremel?
    21 Sep 2011
    Like jossi007 said, boot into safe mode and run malwarebytes.
    I've had a similar problem in the past and this should clear it. AVG picked it up but couldn't get rid of it but malwarebytes could. And it hijacks your internet connection and web browsing so don't do anything online until you've cleared it.
  7. adam_bagpuss
    24 Apr 2009
    sounds like the system interupts issue
    can you check the resource monitor and see if "system interupts" is using some resources.
  8. AMDFTW
    AMDFTW What's a Dremel?
    3 Oct 2011
    look at geting stinger aswell that has sorted many issues for me that have been virus related.
  9. Sarneus
    Sarneus What's a Dremel?
    30 Sep 2011
    Yes it is a virus, I forgot the name now, but I caught it last week too, no idea how because i'm very safe with my PC usage. Anyways like the others said Malwarebytes will fix it.
