Power button with a mind of its own...
Discussion in 'Tech Support' started by noesis, 5 Sep 2007.
  1. noesis
    noesis What's a Dremel?
    3 Mar 2004
    Last night my computer woke me up! I had left it turned off and it started turning itself on and off randomly at intervals of about 5 seconds.
    When I tried to start it this morning it would cut out after around 2 secs then pause for a moment and start booting again. Eventually it made it to windows and is now running ok...
    My system:
    300W Zalman PSU (connected to surge protector)
    A7N8X Deluxe mobo
    Athlon XP 3200+
    1 GB Crucial
    120 gb SATA
    What is the likely cause for this?
    1. Dodgey power supply
    2. Loose cables to power button
    3. Paranormal activity
    4. Others?
    Thanks for your help!
    James
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Are you located in uni halls and connected to there network by anychance, or any other large network for that matter?
    My freind had this happen to him with his pc, turned out that in the bios he had wake on lan events enabled, and someone in the uni halls was sending out wake on events, which caused his pc to power up, several times in a single evening, eventually he just switched it off at the wall, untill he learned that he needed to switch off the wake up events in the bios.
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I hope someone comes up with a solution to this as I have the exact same problem with my penis.
  4. noesis
    3 Mar 2004
    nope - not connected to a network
  5. noesis
    3 Mar 2004
  6. skeletor
    skeletor modder in the making.
    29 Nov 2005
    it could be a bad psu, but i don't think that would explain the random turning on. It may be a bad mobo though, its hard to say. Is there any way you can just put another psu in there to give it a try? PSU would probably be the cheapest thing though just to replace and hope its whats wrong.
  7. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Brilliant! You beat me to it. :lol: :lol: :lol:
  8. Hells_Bliss
    Hells_Bliss What's a Dremel?
    6 Apr 2007
    probably the PSU, do you have a multimeter handy? if so make sure the voltages are within their proper ranges. I think it's the +5v (green wire? not sure) that's the power-on line.
    You should have +-5 +-12 3.3 (and a 1.8 I think)
  9. Delphium
    18 Mar 2007
    It is the green and the black next to it :)
    How To.
