Other power monitor plugs
Discussion in 'Hardware' started by bsp, 17 Feb 2018.
  1. bsp
    bsp Minimodder
    25 Dec 2010
    Any reccomendations for power monitoring plugs?
    I'm having a bit of difficulty as it looks like the market is saturated with them.
    Pros would be backlight and good viewing angles as the devices I want to check are in a bit of an awkward position.
  2. nimbu
    nimbu Multimodder
    28 Nov 2002
    Are you into any home smart tech? I'm pretty sure the Belkin and Samsung ones show power consumption running through them in the Samsung smartphone hub interface.
    Saves having to read them in awkward places and you can set yourself notifications etc
    bsp likes this.
  3. Bungletron
    Bungletron Minimodder
    25 May 2010
    I am using a TP-Link Kasa smart plug (beware there is a non-power version so pick the right one) its pretty good, it connects to your wifi network and displays the power on an Android or iOS app, plus setting the bios to switch on after power failure means I can hard reset my computer remotely if I need to. It is decent!
  4. bsp
    bsp Minimodder
    25 Dec 2010
    Nothing really smart at the moment I'm afraid. Dumb stuff is probably a bit more helpful right now as J don't think I have the resources to buy into a new ecosystem.
  5. Bungletron
    25 May 2010
    no eco system required, the kasa smart plug does not require a hub, connects via wifi. Just need a plug, wifi and a smartphone.
    bsp likes this.
  6. bsp
    bsp Minimodder
    25 Dec 2010
    Awesome!
    Thanks.
