News Power-Over-eSATA announced
Discussion in 'Article Discussion' started by CardJoe, 18 Jan 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. xrain
    xrain Minimodder
    26 Jan 2004
    I almost wont have a reason to keep my hard drives in my computer anymore!
  3. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    The way I see it is that you will only need a small hard drive in your computer for the OS and have everything else stored on a esata drive so you can just unplug and plug into a laptop for example. No need to keep the drive fixed inside a desktop anymore.
  4. ToMMo
    ToMMo What's a Dremel?
    5 Dec 2007
    I agree, the most annoying thing about external hard drives are the amount of plugs and wires involved, this is something i would definitely invest in. With 3 externals but only 2 power leads due to one going kaput, it's a pain to keep swapping them over!
  5. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    thats awesome
    but i wonder how much power is it going to be able to supply?
    enough to run a 3.5" drive?
  6. Guest-23315
    Guest-23315 Guest
    Thats good news!
  7. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Agreed, should be interesting to see how much it can actually run. If it can handle a full sized 3.5" high capacity drive, then I'm very excited!
  8. Renoir
    Renoir What's a Dremel?
    19 Jul 2006
    I'm looking forward to this development. With a bit of luck my next laptop will have this capability. One question about esata though. I've read on wikipedia that "With passive-adapters, the maximum cable length is reduced to 1 meter, due to the absence of compliant eSATA signal levels" so my question is which chipsets have the compliant signal levels and for those that do do they retain the 2m max cable length? Anybody know?
  9. Iorek
    Iorek What's a Dremel?
    18 Jul 2006
    Cool, I don't have any e-Sata yet, but i have a few USB drives that need other power, either pulling a second usb lead or brick. they're a pain :) it'll be nice to be able to power things over one cable (I know some of the USB things are suppose to do it using usb power, but i've not seen it working well yet with bigger disks).
  10. g_gimbert
    g_gimbert Minimodder
    9 Jun 2002
    This is really how it should have been in the first place!
    Although having a server setup for any major storage needs kind of cancels the need for this with me anyway :)
    Certainly would make backing up data easier though without the need to fumble around looking for a power cable.
    [Edit] As I see it, it would also make it easier for average-joe to increase the storage in their PC too? [/Edit]
  11. PhoneyVirus
    PhoneyVirus *_*
    23 Dec 2007
    First things first there are no speeds on this new SATA-IO, and i been hearing talk about this one cable with power over a year now.
    About USB-3.0 now theres something to talk about system I/O will get dramatically upgrade when USB 3.0 makes its debut in the later half of 2008. Details on the updated spec are sketchy, but Intel (the creator of USB) says it and its partners plan to get the ubiquitous standard up to 5Gb/s. Intel says the new spec will be backward-compatible with previous generations of USB but will have the added benefit of being able to run over either copper or optical cabling using the same connector. USB-3.0 will be finalized in the first half of 2008 and have a rollout similar to the high speed USB-2.0 launch: controllers will initially be available via PCI-Express add-in cards, with motherboard integration slated for 2009. Now with that off my head STOP!! and think your 4Gb USB-3.0 drive plug it in, the full 4Gb USB-3.0 drives data can transfer all that in 1s. So SATA-IO if it had optical and at 5Gb/s then there is some to talk about, so i hope to see optical on eSATA SATA in the up coming years.
    PhoneyVirus
  12. Hamish
    25 Nov 2002
    yea cos we all know hard drives are hitting the 3Gb/s limit of sata :duh:
  13. Indybird
    Indybird Why are you reading this?
    14 Jun 2007
    This is very cool, but I've had the thermaltake External enclosure that comes with a molex to enclosure power adapter in an Expansion slot. Though it has "no power block", it is still technically two cables, but that doesn't bother me.
    -Indybird
  14. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    yep, now i keep all my drives fixed inside my fileserver:D. esata is an enthusiast technology. i don't really see a market for esata-only drives. there is no point in me buying a disk that i can only plug into my computer. i want to be able to bring it over to my friends place and plug it into his computer too.
    current flash memory has a hard time saturating the 480Mb/s provided by usb2. at this point, usb3 is just wasted bandwidth. also, 4Gb (gigabit) != 4GB (gigabyte). storage is talked about in bytes, bandwidth in bits. eight bits in a byte.
  15. Hamish
    25 Nov 2002
    thats what external enclosures are for ;)
    i already have a USB + eSATA external caddy, use eSATA on my machine but can hook up USB to connect to others
  16. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    There's a solution available now which would suit your needs - namely Ultra's 'Stackable' devices :idea:
    [​IMG] (Original pics courtesy of Bjorn 2D)
    All the devices are connected to/powered by a single, 180w PSU... such that the PSU itself, is the only device in the 'stack' which requires plugging into the mains :cooldude:
    The only drawback I can see with it, is that you can only use Ultra's own products in the 'stack' :idea:
  17. iwod
    iwod What's a Dremel?
    22 Jul 2007
    I hope it can power the Western Digital GP Series 3.5" Drive
Tags: Add Tags
