Networks Powerline networking?
Discussion in 'Hardware' started by .//TuNdRa, 5 Oct 2012.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    So A few of you might've caught my constant raging about Wireless in this house; I'm going for a new approach; Powerline Networking.
    So a few basic questions; Should I have them before the Surge Protector in my room, or won't it make much of a difference? And is it worth splurging out for the extra 500mb adaptors when so far as I can see; there's not much of a performance improvement for supposed 2.5X extra bandwidth.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Generally powerline plugs need to be plugged straight into the wall socket.
    My experience of this has been as follows, my sons and my daughters are in four way adapters and work fine, my wife's on the other hand (exact same make) utterly refused to work in one adapter but was fine in another.
    As for speed get the highest you can afford so you don't end up having to re-buy later on, we are still on 85mbps ones and no one is complaining but then we don't stream hd or anything.
  3. Ferino
    Ferino Minimodder
    26 Mar 2010
    I started running with 200mbps ones, but was struggling to play blu ray rips across the network (dvd was fine though). I have mine straight into the wall, as most websites suggest that that is the ideal. When moving files across cat5e and powerline 200mbps i was getting real world speeds of about 7Mbps. With 500mbps it's more like 15Mbps.
    Hope that helps.
  4. .//TuNdRa
    12 Feb 2011
    Hrm. Well it would definitely be more consistent than my wireless, but no faster if that rings true. I find myself wondering how they can sell them as "500mb" adaptors when real world speeds are that hideously low. What were they using to test? Two wall sockets within two feet of each-other?
  5. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    Surge protectors and the like will stop them working, they'll filter out the 'rogue' signals as part of how they function, meaning the network signal won't get through.
    I had a set of 85mbps ones for quite a while and streaming HD was fine. I'd still advise getting as fast as you can, as CrapBag said.
    The quality of the wiring in the house can has a massive impact on the speed and stability though.
  6. .//TuNdRa
    12 Feb 2011
    So assuming I get a reasonable signal throughout the house; What'd be the best set to go for for under £50 where possible, I've found a D-link set that looks like it ought to fit the bill, but does anyone have any experience with those.
    I'm well aware the Zyxel set on Scan is cheaper, but it's 100mb ethernet ports only, which makes it a waste of the extra 400mb of theoretical bandwidth when it's bottlenecked at either end anyhow. (Bit-tech even acknowledged this in their review of said kit.)
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Best are Delovo, but i get Solwise as they use the same chip in the AV 500 not sure about AV200 and cost less. Naturally they cost more than the melting cheap china brands and yes a friend of mine had a Homeplug melt. ()free sh t from sky)
  8. law99
    law99 Custom User Title
    24 Sep 2009
    I know someone who used powerline networking. Kept returning them saying they didn't work. Turns out, his house was on two circuit breakers... lol
    I'd avoid to be fair, unless you have to. Slow they used to be. Slow.
  9. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    This is why you dont buy the crap ones.
    i HAD RUNNING THROUGH 2 MAINS BREAKERS (caps ops) and had 100% signal.
    Quality German solid-core wiring though.
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Mine are only cheapo ebuyer ones, get a little warm but haven't had any issues with meltdowns :~)
  11. .//TuNdRa
    12 Feb 2011
    I know this house was built in the 70's, with wiring to fit. The upstairs and downstairs are on two different ring mains, but they're connected through only a Fusebox.
    I'm assuming that wouldn't help with bandwidth at all, but I'm also assuming that, at least, I'd have better than crappy 2mb wireless bandwidth that I get up here.
  12. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    I would suggest to get Solwise over amazon and us DSR if the speed is really slow.
    I would not suggest anything under AV200 tbh.
  13. Ferino
    Ferino Minimodder
    26 Mar 2010
    The advertising is down to Bits and bytes I guess. And the old UP TO catchall.
    500mbps should theoretically get you to 62.5Mbps then throw in signal loss over the mains. 15Mbps per second is fine for streaming full Blu ray rips across the network (and across floors) in my house, where as the wireless signal is horrendous due to very thick old stone walls. Horses for courses.
  14. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Thats why I stumped up for the AV500 for my network as more then one PC accesses internet and Media server over the connection. Remember to think of it as radio signal over cables and not LAN. As all signal share the one backbone and are not on separate cables.
    BTW: Solwise use intel network chips as well, which are better then marvel of the cheaper brands. Can find in reviews my network has been up and running for about a year now so I got non of my research links sorry.
    http://www.solwise.co.uk/net-powerline-500av-index.htm
  15. Strudul
    Strudul ~
    31 May 2010
    I've been use powerline adapters for years now.
    ATM I'm using 1000Mbps Solwise adapters. I know they are supposed to be plugged directly into the mains socket, but I have mine plugged into a power strip (used to have it plugged into a power strip, which was plugged into another power strip, which was plugged into an electricity monitor thing, which was then plugged into the mains).
    I did try plugging it directly into the mains and never really noticed any difference to be honest.
    There have been a few occasions where I have had to unplug and re-plug the adapter (one or both ends), but most of the time it is fine.
  16. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    I'm using TP-Link AV200 (PA 211)'s for my WHS box to TV, plugged into adapters, wiring just over 20 years old, to stream video, Divx and MKV, works fine, very handy...
  17. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Been using 200Mb adapters for almost a year now. So far speed has never really been an issue, it's always faster than my internet connection which is number one priority so that's one advantage over the WiFi I'd have otherwise been stuck with which as you well know is notorious for spotty connections. I also stream movies and TV shows in both 720p and 1080p and it's worked just fine for the most part (I blame PS3 Media Server for any problems). None of my stuff is terribly high bitrate so who knows.
  18. rollo
    rollo Modder
    16 May 2008
    Power line adapters are as bad as wireless in older houses.
  19. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    Everything I've read suggests you should use the mains outlet, but I have a few friends that use them on power adapters too with only minor speed degradation... go figure!
  20. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Our house is 35 years old, powerline is wiping the floor with wireless here, no more dropouts for seemingly no reason.
