Hello everyone, Am completely new to the bit-tech forum, but can directly enjoy all the other different build logs. I would like to share my first build log. I had a desk that was too small for my stuff. The money was not there, so I waited for several years and used the old desk / computer. Because time and money is available, I worked out my plan. After looking at other mods, I found that the "desk mod" is the best and will be most practical for me. The idea has combine two computer in a desk. ------------------------------------------------------------------------------------------------------------------------ Old desk ------------------------------------------------------------------------------------------------------------------------ The Design ------------------------------------------------------------------------------------------------------------------------ Sneak-peak result ------------------------------------------------------------------------------------------------------------------------ Hardware 1. ‘Main-PC’ (left-side) Intel I7-4770K Asus Z87-Deluxe ATI R9 290X 2 x Kingston Fury Black 8GB M4-CT128M4 SSD 128GB Western Digital WD10EADS HDD 1TB 2 x Liyama LXB2483HSU-B1 Cooler Master V series 850 ATX23 (Full-modulair) 2. ‘Server-PC’ (right-side) AMD Athlon II X4 640 Asus M4A78LT-M Samsung Spinpoint M8 500GB Kingston KVR13N9S8H/4 Cooler Master Silent Pro M2 850W/1000W 3. Accessory Logitech G400S Cooler Master Speed-RX Large Razer Kraken 7.1 4. Water cooling stuff EK-FC R9 290X – Nickel Koolance Drain Valve 10mm (1/2 OD) 2 x Akasa 5-poorts ventilator cable 6 x Bitfenix Spectre 120mm rood led 10 x 10mm 1/2OD - G1/4 Alphacool VPP655 Bitspower Water Tanks Z-Multi 150 DangerDen DD-M6 Brass CPU Block EK-Coolstream PE 360 Radiator Feser Tube UV 2 x Lian Li PW-IS40AV85AIO I/O-panel Mesh panel
Building fase ########################## Edit material fase ################################ Computer testing fase ############################################ Final fase
