Pre-fitted WC Graphics cards
Discussion in 'Watercooling' started by Wing Zero, 20 May 2010.
  1. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    Been looking at your range of graphics cards with pre-fitted WC blocks here. who makes these cards. reason i ask is because the ATI cards, their power connectors appear to be on the top right of the card pointing upwards (which would be perfect for me). most of the other ATI cards i notice put the power connectors sticking out to the side (which would clash with a Rad on my case)
    was hoping to buy a normal card, run on air cooling till i can afford to fit a WC block of my own. otherwise i would buy one with a WC block pre-installed, because i assume it's then covered by warranty
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    i think they are just ref design cards as far as i know but ill check in to it for you.
  3. aquatuning
    5 Jul 2006
    powercolor, sapphire, xfx, club3d and others is the reply i got lol
  4. Wing Zero
    28 Apr 2010
    just waiting on the 5850 to come into stock, it was the 6th, now it's been pushed to the 11th, but have not received any notices yet on if it's been shipped out to me yet.
