HTPC Preventing media center from accessing files?
Discussion in 'Hardware' started by shroom, 16 Feb 2007.
  1. shroom
    shroom What's a Dremel?
    6 Aug 2003
    I live in an apartment with three other people, we have one big tv, one xbox 360, and we all have computers. I'm running Vista, so the extender comes installed and lets me listen to music/videos on the tv, which is all fine and good, except for the fact that anyone sitting at the tv with the 360 remote has access to all the media on my pc, no matter if its in a shared folder or not.
    Is there a way to prevent them from browsing any files other than what I've added to the library?
  2. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Password protect them?
  3. sk8phreak88
    sk8phreak88 Minimodder
    8 Aug 2004
    Gots to hide the stash o pRon? LOL
    Best guess would be the password maybe? I don't know really.. I wish my 360 would configure with my network so I can stream stuff.. BUt it wont for some reason or another :/
  4. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    is it really set up that badly?? that is shocking on MSs part!
    could you find out what user it uses to view the files (i guess its done over C$ etc)
    so do a
    "net sessions" from command, find the user, and then remove access to the hard disks/folders from the file permission area on the folders.
    to be fair I am shocked that the 360 can browse EVERYTHING its quite bad -- check the 360s settings to see how it is browsing the folders as well -- you could remove the C$ etc shares and then add some shares for the folders that you want shared.
  5. shroom
    6 Aug 2003
    Yeah, I'm really surprised that there isnt a privacy lockdown of some kind. Say I was a parent and didnt want my children viewing the files on my computer?
  6. shroom
    6 Aug 2003
    I found something that might work, we'll see how well it gets along vista.
    http://platinumedeals.com/kip.aspx
    Edit: Just a heads up. I would not recommend installing KIP on Vista. Lets just say it took two days to regain access to my personal files and I won't be getting my xp partition working any time soon.
