Problem with CoolerMaster ML240R RGB
Discussion in 'Watercooling' started by Mayo666, 16 Nov 2020.
  1. Mayo666
    Mayo666 What's a Dremel?
    11 Nov 2020
    Hi all,
    first of all sorry for bad english, I hope I will be able to explain quite well the situation..
    It was a few day that the temperature of my CPU seemed to be a little too high (I am checking it with an Aida64 panel) and yesterday suddendly the temp. went to 89 C° degree and the pump of my AIO to maximun ...
    I decided to switch all off, demount the AIO to check if there were mount problems... but i got a bad surprise, pls see images
    After having cleaned-up I re-mount the AIO but nothing to do, temp still at 89° ..
    Now I wrote to C.M. to check if my AIO is a 2 years or a 5 years warranty product
    (th AIO has 2 years and 5 months ....)
    What can be happened??
      File size:
      351.4 KB
      20
      File size:
      327.4 KB
      20
      File size:
      412.5 KB
      20
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    It looks like it may have leaked a bit!
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    Yup seems your AIO is dead.
  4. Mayo666
    11 Nov 2020
    Unfortunately yes...
    I wrote to Cooler Master hoping warranty is longer than 2 years on this AIO .. I will wait for an answer but less than 2 and a half years is a short life time .... isn't it?
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    Even though it's out of warranty, that's quite a disastrous failure so it's always worth a try.
  6. Mayo666
    11 Nov 2020
    At the moment the answer is NO warranty .. it is finished on begin of July ... but I am sure that all the
    encrustations are even older ... I will try to ask a discount on a new product ...
  7. yuusou
    yuusou Multimodder
    5 Nov 2006
    Tweet them about it, put the photo public, make an angry rant. Socially manipulate the situation as it really should not have failed so soon so spectacularly.
  8. Mayo666
    11 Nov 2020
    this seems a good idea!
  9. Mayo666
    11 Nov 2020
    I wrote on 2 italian forums in the section C.M. support ...
    Someone said he will take to the attn. of CM...
    Even if I do not think they will give me a positive answer... is better than nothing, will see...
  10. Mayo666
    11 Nov 2020
    On ufficial CM site they told me to send the AIO in Netherland, if it is really broken, probably they will send me a new one ...
    I will keep you updated
    Bloody_Pete and Mr_Mistoffelees like this.
  11. Mayo666
    11 Nov 2020
    Good news mates!
    Today I receved the new AIO from Cooler Master Netherland!!!
    GOOD JOB Cooler Master and thank-you!
    Bloody_Pete likes this.
  12. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    Same thing happened to mine not even with 1.5 years of use but since I bought it two years ago ... Tough
  13. Mayo666
    11 Nov 2020
    I hope the new AIO cooler will last a little longer....
    I have a question and may be someone of you may help:
    the mobo is vertical in my TT P3 case and I have to mount the radiator vertical too: the point where the tubes go in the radiator should stay on top or on bottom?
    Best rgds
  14. Bloody_Pete
    11 Aug 2008
    As long as the pump is lower than the radiator, so the top will proobably be best.
  15. Mayo666
    11 Nov 2020
    do you think in this way it is ok?
