Programming help, anyone?
Discussion in 'General' started by Shadow[X], 29 Mar 2001.
  1. Shadow[X]
    Shadow[X] da <a href="http://www.shadow-x.co.uk">Shadow[X]</
    12 Mar 2001
  2. Gav
    Gav What's a Dremel?
    12 Mar 2001
    see message posted at above board.
    If you cant be bthered then it may be possible to use a ssi command to include a file/page within another file/page.
  3. Shadow[X]
    12 Mar 2001
    yes, ssi is all well and good, but it has to be embedded into a pre-made page. i want to convert an asp call to an include, so default.asp?view=page1.inc would build the default.asp page and insert the page1.inc file in it.
