Case Mod - In Progress [Project 04]
Discussion in 'Project Logs' started by Tipchic, 20 Feb 2015.
  1. Tipchic
    Tipchic ***
    3 Jul 2008
    Hello my friends! :clap:
    I started new case mod "Project 04".
    Until have no idea about design.
    Objective - create quiet, reliable case.
    So...i bought old workstation HP.
    Because it made of steel 1 and 1.2mm.
    Dimensions 450x420x165mm. Empty weight 9kg. (w/o PSU)
    Better to do well, than to say well :dremel:
    Case
    Disassembling
    Some bad news.
    No ATX PSU. (at right)
    Unique configuration of mounting holes.
    For standart i/o shield need cutoff something.
    Mobo tray, cooler backplate and i/o shield in one piece.
    Some good news.
    Mounting hole for ATX mobo.
    Few brass spacer and tap it's all i need. :thumb:
    To be continued...
  2. Tipchic
    Tipchic ***
    3 Jul 2008
    Next...
    Try mount PSU
    Sketch of PSU plate.
  3. Tipchic
    Tipchic ***
    3 Jul 2008
    Today create PSU plate and ... and... for i/o shield.. help me find words! :wallbash:
    PSU plate in process. Made of 1.2mm steel.
    Result
