Scratch Build – In Progress Project 3: l'ex tonneau,"COMPLETED"
Discussion in 'Project Logs' started by AM Modding, 20 May 2016.
  1. AM Modding
    AM Modding What's a Dremel?
    11 May 2016
    Hi everyone,
    it's been that I admire the different mods that can be seen here , and I decided to get serious in the modding with this project.
    I show you pictures in chronological order and the explanations
    at the beginning
    after sanding
    Installing hinges and feet
    Installing a system to keep the case open when using the pc
    Preview size
    I tested the installation of seat belts
    I hesitate between tight or discarded ?
    Next steps
    - Setting up square to strengthen
    - Then positioning belts to hide the hinges and afford to keep the case closed during transport
    - And setting up of the power supply
    - Then implementing the cm and all that goes with (i / o shield , support, cooling ... )
    - Then setting up a desert plant next to the config in the housing
    - And finally finding a name for the mod
    My objective
    for this mod is a portable housing , natural ( raw wood and integration of a plant ) , and with the look of a vintage trunk as the subject lends itself well and I find it simpa .
    Right now I paused waiting for parts , but I'll be back soon (maybe with a sponsor ;))
    Meanwhile I answer with pleasure your questions!
    ps:
    sorry for the mistakes , I'm French and I use google translation
  2. AM Modding
    11 May 2016
    Well well well ... I'm back !
    First Silverstone has accepted to help me in my project by sponsoring me .
    For the uneducated , this is a brand that manufactures housings ( housing and accessories), cpu cooling, and power supplies ...
    http://www.silverstonetek.com
    Here's what they were providing me :
    - un aio TD03-LITE http://www.silverstonetek.com/product.php?pid=586&area=en
    - A fully modular PSU sfx and semi passive SX600 - g [/ b] http://www.silverstonetek.com/product.php?pid=524&area=en
    [url]http://zupimages.net/up/16/21/olrx.png[/url][/ img]
    it allowed me to move forward
    [img]http://zupimages.net/up/16/21/o5ed.jpg
    That's it!
  3. AM Modding
    11 May 2016
    I still have some details to settle , but I 'm almost done
  4. AM Modding
    11 May 2016
    it only needs the graphics card and the External finishes
    What do you think of my work ?
  5. AM Modding
    11 May 2016
    nobody gives its opinion ?
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I like it a lot :)
    Will you also do work on the hardware itself?
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Orginal mod :clap:
    You should change the mobo tray and use some wood.
  8. Quantum-192
    Quantum-192 What's a Dremel?
    1 Jul 2016
    Very original it should look really good when complete.
  9. AM Modding
    11 May 2016
    "Will you also do work on the hardware itself?"
    No, I want to keep warranty
    "You should change the mobo tray and use some wood."
    I wanted to use wood, but it was too twisted and forced it too much into the rails
    Thank you for your review and compliments
  10. Hukkel
    20 Dec 2012
    :nono:
  11. AM Modding
    11 May 2016
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    i absolutely love the 2 last pictures!
    this build is sooo cool.
  13. amagriva
    amagriva Minimodder
    13 Jun 2009
    :brrr::duh::eyebrow:
  14. AM Modding
    11 May 2016
    Thanks !!
  15. AM Modding
    11 May 2016
  16. AM Modding
    11 May 2016
    So here it is time to put an end to this mod which I hope you will have liked. For me in any case it allowed me to learn a lot and I had a lot of fun.
    Although it is not perfect, I could still spend time and money for the finishes, but I have neither, and the box as it pleases my brother so it is the main.
    I thank Silverstone without whom this project would not have been born
    As well as all of you who have supported me and / or helped with the project
    See you soon on another project
  17. Cown
    Cown Minimodder
    25 Feb 2012
    Gratz and nice work! I think even my wife would approve of this haha :D
  18. AM Modding
    11 May 2016
    Thanks !!!
    I doesn't have a wife but my mom approve too :D
