Case Mod - In Progress Project 4: Renaissance of the Phœnix
Discussion in 'Project Logs' started by AM Modding, 11 Mar 2017.
  1. AM Modding
    AM Modding What's a Dremel?
    11 May 2016
    Hi everyone,
    I have a small modding case going for a friend
    It is called Renaissance of the Phoenix because I give life to an old tower of the years 2000. The main colors will be the gold (and derivatives) as well as the black.
    It's a quick little budget mod made with what drags on the cupboards (for the case)
    As for the config it will be new, i5, rx480, 8gb ram, ssd, hdd, in short the comfortable :D
    To follow cutting, painting and mounting ... :dremel:
  2. Vault-Tec
    30 Aug 2015
    Wow a slider case ! not seen one of those in a few years. Alienware used to use the smaller model.
    They were made between 1996 and 1998 :) after that Alienware moved to the Chieftec Dragon.
    This boring fact was brought to you by Vault-Tec. Remember kids, duck and cover !
  3. AM Modding
    11 May 2016
    Ah I did not know, thank you very much for this information, I now know that the case is older than me :D
  4. AM Modding
    11 May 2016
    First cut-outs at the top of the case and first tests
  5. AM Modding
    11 May 2016
    The equipement will be
    Seagate BarraCuda 1 To
    Kingston SSD UV400 120 Go
    ASUS PRIME B250-PLUS
    Intel Core i5-7400 (3.0 GHz)
    MSI Radeon RX 480 GAMING X 4G
    Thermaltake TR2 500W Gold
    ASUS Cerberus Keyboard
    Logitech Wireless Mouse M235 (Rouge)
    Microsoft Windows 10 Famille 64 bits - OEM (DVD)
    be quiet! Dark Rock 3
    DeepCool RGB 360
    Corsair Vengeance LPX Series Low Profile 8 Go (2x 4 Go) DDR4 2133 MHz CL13
  6. AM Modding
    11 May 2016
    Hop hop, we don't waste time, the following
    Cutouts
    Logo test
    Paint test
    Fail paint effect test
    Final paint effect
    Start of the final paint
  7. AM Modding
    11 May 2016
    First update of the WE, it will have a second tomorrow
    :rock:
  8. AM Modding
    11 May 2016
    Second update of the WE
  9. storm-83
    storm-83 Minimodder
    7 Nov 2014
    you should give him 1gb worth of storage, spread out on 48 drives(~20gigs each), because y2k...
    Love me a grey mod, so will be looking forward to more updates!
  10. AM Modding
    11 May 2016
    Thank you ! It Will be finished this week with an extra for you guys
  11. AM Modding
    11 May 2016
  12. AM Modding
    11 May 2016
    3 2 1 Test [ON]
  13. AM Modding
    11 May 2016
  14. AM Modding
    11 May 2016
