Scratch Build – In Progress Project Alpha-Custom, 3rd Jan, 11
Discussion in 'Project Logs' started by sc0ontz, 29 Dec 2010.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome case mate & I am highly impressed with your diy work especially the pci/io piece I know how difficult it is to get the bending correct on that part :D:jawdrop::thumb:. +rep
  2. sc0ontz
    sc0ontz I'm a modder... I guess... :D
    30 Aug 2009
    thanks man!
    thanks mate, it took me 3 scratches just to come up with correct bending method for the mobo back panel... i almost quit this part and replace it with a generic casing mobo back panel...:sigh: good thing motivation kicks in to finish piece.:D
  3. paultan
    paultan R E V E N T O N
    22 Jan 2010
    go pinoy^^ pinoy ka din pala sir^^
  4. sc0ontz
    30 Aug 2009
    yes sir! pinoy na pinoy ito! and proud to be one!
    Happy new year to all!!! Just got back from a short vacation!
    Well, a new year is here and new idea has came in...:idea: I have decided to make the case shorter and smaller... so, I redid the motherboard tray... also i have thought of a design for the sidepanel and also a new design for the front panel... (thanks cchr, I got some help from him)
    All these ideas are coming in but I have a bit of a problem!!! I have used up the remaining aluminum that i have...:waah: good thing I was able to fit in the new motherboard tray.:dremel: I think, the rest of the build will be on acrylic and some body fillers...
    So here's some photos of it:
    The last piece for the mobo tray and a little scrap piece.
    Marked the holes for the pci slots
    Drilled some holes on it...:thumb:
    Ready to hand file it
    after a few minutes of filing... pci slot holes... done!:D
    test fitting...
    time to drill some holes for the sata cables
    a bit of hand filing... it looks good... i guess!
    access hole for the pci cable... underneath the motherboard...
    holes for the 24pin, 8pin and a access hole for the cpu cooler... this slot id for the the P/H55 mobos
    time to bend the corners... got lazy setting up the bender... so, bended it using a pair of wood...:D
    well, I guess it looks good!
    final photos...
    A day's work is done!:clap:
  5. that_du^de
    that_du^de give your head a wobble
    29 Nov 2010
    i like the taper you got on the top frame going from thick to near flat good bit of thinking that.looking good mate!
  6. sc0ontz
    30 Aug 2009
    thanks mate!
