Project: Alucard case
Discussion in 'Project Logs' started by g_sanke, 4 Jul 2006.
  1. g_sanke
    g_sanke I PREGUNTA!
    17 Sep 2004
    This is being posted about 35 - 40% into completion, so no day one or anything.
    This is also my first project to post about.
    Its been a slow process but i will post all the pictures leading up to now and all new ones. If ANYONE has any feedback or ideas i should go with, please tell me. I'm very open to opinion on mods, i enjoy other peoples input!
    As the title says this is called Alucard case. And yes its the alucard from Hellsing, even though its more of a hellsing mod instead of just alucard.
    The case im using is an Antec x800 or x1000 i really dont remember. But non-the-less the theme is blood and vampires, just like hellsing.
    ok, now to pics...
    This is what i did with the panal on the mobo side, kind of a mural Alucard painting
    heres where i kinda got the idea from (if you have never seen the anime)
    http://www.fujitv.co.jp/jp/b_hp/hellsing/photo/hellsing_wallpaper01.jpg
    Safety First!
    After measuring and sketching i went through lots of ideas for the window, but after seeing the Ultimate OVA announcement site, i went with the crossed crosses...
    After dremeling... for a while (WHY IN GODS NAME DO DISKS BREAK MORE ON CARDBOARD THAN METAL!??!??!?!???!) 38 disks broke.
    yay spray foam and bondo!
    after sanding the bondo and adding the first layer of paints... im adding more tomorow.
    my next phase will be to finish out the window by adding aluminum platting to the vertical cross and clear plexi to the horizontal window. While doing that ill bbe working on the from bezel. more pics soon! please give me ideas for the top, i plan to add a grill for the radiator up there.
  2. Atomsk
    Atomsk What's a Dremel?
    13 Mar 2004
    woot almost makes me wish I hadnt given you that case :p Im telling you dude stick with the plexi on both crosses :dremel:
  3. g_sanke
    g_sanke I PREGUNTA!
    17 Sep 2004
    happy july 4th!
    ok not a huge update today, got the plexi cut out and in the window.
    this image i just took to show refleciton!
    more updates coming soon. Next phase is the front bezel
