Scratch Build – Complete ⭐ PROJECT ARCHERON
Discussion in 'Project Logs' started by Baden, 6 Dec 2017.
  1. Baden
    Baden What's a Dremel?
    6 Dec 2017
    Hi guys!
    This is my first scratch build and also my first project work logs. Hope you guys can correct me if i bend any forum rules.
    And also this is a personal projects so there are some restriction or lackness from my own side in case of materials and components used.
    This project is named Archeron.
    It is based on one standing wall where all the components are mount on two layer 5mm thickness acrylic panel.
    The base body is covered by mecha-like armor as sidepanel on each side which is at left and right side. Between two layer acrylic there are 10mm gap for cable management purpose where all ugly cable will be hidden.
    The main color theme will be black and metalgrey/metallish looks. There are also weathered or damaged add on to the paint job as this was the main highlight of this build.
    This projects is on progress right now and i will update any progress whenever i have time.
    Thanks!
    Hope you guys can advice me or give any suggestion for this build.
  2. Baden
    6 Dec 2017
    Some update on project progress
    After my final design on the build is done. I spend some time for acquiring the materials will be used later on.
    In this build i mainly used acrylic sheet varying in thickness
    -3mm x1
    -5mm x1
    -8mm x1
    I try to find acrylic sheet with 10mm thickness but unfortunately at that time the hardware shop are currently out of stock. So i decided to proceed with 8mm instead.
    Cutting the main body
    5mm thick acrylic is used for the main body part and cut with laser cutting machine.
    This is how the main body looks after the cut
    As the main body is consisted of two layer of 5mm acrylic,i used some 8mm acrylic spacer to create a strong gap between the body. Both layers are reinforced with m3 screws and nuts.
    Bottom base/Stand
    I try to make a main body support exactly as designated but found out it was not strong enough to hold main body. Back to drawing board and figure out a new and also strong support for the main body.
    The base i used is only 5mm thick acrylic so does the main body holder at the top. Maybe i need to use a thicker acrylic. I will update the result of the new stand.
    Thanks for following!
  3. Baden
    6 Dec 2017
    New stand for main body
    Hi guys
    Here are some update on the failed stand or base of my scratch build.
    I decided to use a broader bottom base and thicker main body holder for stronger support.
    This is how it looks after screws and nuts
    Next i'm going to figure out on mounting psu and also radiator position on the main body.
  4. Cheapskate
    13 May 2007
    :thumb: Looking good.
  5. Baden
    6 Dec 2017
    thx man :happy:
  6. Baden
    6 Dec 2017
    Some updates on the project
    I've done working on sfx psu positioning
    Here are some pics on the 240mm positioning and under experiment main armor(sidepanel) holder
  7. Baden
    6 Dec 2017
    It seem my sidepanel holder are not that strong enough so i change it. i change to 12mm acrylic tube stronger and more decent looks than previous square acrylic holder.
    Gluing sidepanel.Consist of two layers acrylic
    Mounting base armor(sidepanel)
    That's it for now. Gonna put some paint job on the main body and sidepanel. Thx for following peeps. See you soon!
  8. Cheapskate
    13 May 2007
    Neat! You could add a sliding GPU bracket to the tubes. I think some perpendicular panels in the gaps would look good too.
    "Kangaroo pants" - I need to get my eyes fixed. :lol:
  9. Baden
    6 Dec 2017
    Good suggestion. Will try experimenting that too :dremel:. But if it steel tubes i can make it happen right away. This acrylic tubes i'm not sure can hold that much gpu weight. We will see
  10. Baden
    6 Dec 2017
    First of all,thx to Kingmax for supporting this project
    KINGMAX Zeus Gaming Ram 3000MHZ 8GBx4
    KINGMAX 240GB SSD
    Paint job time!
    Decorative chrome for the undercoat and flat black for outer layer.
    Sanding with 400 and 800 grit sand paper to get the worn metal look
    Assembling main body frame and quick watercooling assembly
    Main frame i use carbon sticker to wrap it up.
    Bleeding time
    That's it for now. Thx for stopping by!
  11. Baden
    6 Dec 2017
    Finally it's done!
    Dot_Kappa likes this.
  12. Cristianodanna mod
    Cristianodanna mod Minimodder
    16 Dec 2016
    good
    Baden likes this.
  13. kim
    kim hardware addict
    10 Jan 2016
    great design :thumb:
    Baden likes this.
  14. Cheapskate
    13 May 2007
    Love it! :thumb: It came out great. The silver/wet sanding looks a lot more realistic that just drybrushing silver paint on.
    Baden likes this.
