Scratch Build – In Progress [project]-=BARATiX=-
Discussion in 'Project Logs' started by FLIPC, 9 Nov 2008.
  1. FLIPC
    FLIPC What's a Dremel?
    18 Aug 2006
    Hello after a long long abscence...
    Here is my new project: BARATiX
    Informations:
    A cube mod, nothing special you tell me ...
    The difference is that I'm inspired of barebones but in ATX
    BARATiX is compressionn between BARbone and ATX
    Specifications:
    Width: 370mm
    Length: 370mm
    Height: 400mm
    Building materials: wood (maybe different later)
    Color: -unknown for now-
    Ze Flip Toutch ': carputer + mp3/divxBox
    Integration:
    -1 HD
    -1 Fan Regulator
    -power supply, motherboard, sound card, video card, player / CD / DVD (really.......)
    -1 Neon (or 2) inside color: -unknown-
    -1 switch for the neon
    Status:
    creation plans: 100% 7 of 7 faces (one by side of the cube)
    creation of the cube: 30% 6 of 7 plates cut (but none finished)
    finish: 0%
    overview:
    What should it look :)
  2. FLIPC
    18 Aug 2006
    I' have began the realisation of the case:
    Front:
    Inside: (missing a HD near the cut in the lateral pannel)
    Overvieuw:
  3. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    I have made such a project before. I used MDF (thats how its called in Dutch, probably the same material that youre using now. I can see it because thare is no structure in the wood). If you got any questions, i can help (in Dutch).
  4. FLIPC
    18 Aug 2006
    thanks
    yes i'm using MDF
    Some news:
    The space will be filled with mastic (for the finishing step)
    The front (missing the plexi)
    Overview (the fan is not fixed)
    [​IMG][​IMG]
    Détail of the fixing
  5. slap-o-mite
    slap-o-mite What's a Dremel?
    14 Nov 2008
    Are u gonna brace the inside of the right angles to add support ? like with angle molding stock ? Or are u going to use the metal on the outside ?
  6. FLIPC
    18 Aug 2006
    @slap-o: i don't understand well your question (i have not practiced english since a long time... :( )
    But if i understand well, you 're asking to know how i will fix the support?
  7. FLIPC
    18 Aug 2006
    PS: sorry for de answering time slap-o
    Some news:
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  8. FLIPC
    18 Aug 2006
    paint done with "blingbling" effect :p
