Case Mod - In Progress Project "Big Machine"
Discussion in 'Project Logs' started by barracuda, 26 Jul 2008.
  1. barracuda
    barracuda What's a Dremel?
    19 Jul 2008
    The original pictures of the casing.
  2. barracuda
    19 Jul 2008
    1st part of the mod.
    I have done a square part as a see thru window.
    The 9 bays of the 5.25 Bracket has been cut off.Only left 3 5.25 bays.
  3. barracuda
    19 Jul 2008
  4. barracuda
    19 Jul 2008
    Making a motherboard tray.
    The huge motherboard tray are taken out from the chassis.
    I took me 20 minutes to take it out.
    Measuring the size i need to cut out.
    Thinking to use the old motherboard tray,but nah,its ugly.
    Here are the pictures of the 2X 80MM exhaust fan hole.
  5. barracuda
    19 Jul 2008
  6. barracuda
    19 Jul 2008
    The 5.25 & 3.5 Bay painted 1st layer of primer coat.
    The motherboard tray painted with silver as base coat,beige as 2nd coat,and will add gold as 3rd layer coating.
    The 120mm Radiator Grill.
  7. barracuda
    19 Jul 2008
    The radgrill already undergone filing works.
    Here i made a small rounded holes.
  8. barracuda
    19 Jul 2008
    SIDE PANEL.
  9. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    going to be one great mod when finished! loving it!
  10. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    this looks like it's going to be awesome:)
    Big cases=big mods... *Subb'd*
  11. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    start from on old case an have already a nice mod :thumb:
  12. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    That's a decently sized case :)
  13. barracuda
    19 Jul 2008
    Thank you guys.I will update again later.Still busy sanding before getting to paint it.
  14. ednismod
    ednismod Minimodder
    15 Oct 2007
    Wow, that's really big! Hehe.
  15. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    I'm liking the looks of this one.
    Subbed!
  16. barracuda
    19 Jul 2008
    Thank you guys.
    Here the small updates.
    Pictures after some sanding.
    This is after applying 1st coat.
  17. bigsharn
    9 May 2008
    wait a sec... is that a dual PSU mount?:jawdrop:
  18. barracuda
    19 Jul 2008
    Yes.It is a dual PSU mount.:naughty:
    Small Updates
  19. bigsharn
    9 May 2008
    :jawdrop:
    pity they don't have a :drool: smiley otherwise I'd use that:p
  20. 330td
    330td Minimodder
    12 Aug 2004
    It seems to be a good start, keep on modding :dremel:
