Case Mod - In Progress Project | Black-SpitFire - Updated 20th Nov
Discussion in 'Project Logs' started by keir, 16 Jan 2006.
  1. Guest-23315
    Guest-23315 Guest
    Glad to see you used my rad placing advice!
    How quiet are those fans?
  2. keir
    keir S p i t F i r e
    5 Oct 2003
    :D
    Very very quiet.
    I'm going to attempt to drain the loop, and cut and stoof.
    wish me luck :brrr:
  3. ledbythereaper
    ledbythereaper New Member
    2 Jan 2007
    I was going to say that a 120.1 isn't going to effective at cooling that loop but now I've seen you've added the 120.3, reminds me of something I read in Custom PC when a guy had a huge rad mounted to the wall outside his house.
  4. keir
    5 Oct 2003
    Right tubing sorted no leaks :)
    Temps are well better, after 2 hours of TF2 I've got :
    And this is with the window closed.
    Need to do something about that system temp..
    Will post images later.
  5. keir
    5 Oct 2003
    quick update on the temps.
    This is during 2 hours of TF2 but with the window open for a bit.
    Sortly after that screen shot I got CPU @ 32 nd GPU @ 37
  6. tolis86
    tolis86 New Member
    3 Nov 2006
    system temperature refers to northbridge? man....its hght if itw acurate....
  7. keir
    5 Oct 2003
    Yeah it's heat pipe cooled, chipset temps are always high IIRC
  8. doubble_d
    doubble_d mystery box
    21 Nov 2007
    nice work man i love this case...... keep up the good work //doubble_d and mystery box 2.0
  9. tolis86
    tolis86 New Member
    3 Nov 2006
    you realy must add a 12cm fan at the back of the case.imho...
    73 degrees are very high... especialy in winter....imagine what temps youll have in summer...
  10. Angleus
    Angleus New Member
    28 Nov 2007
    Hey keir I have this case too (love lian li) and am planning to water cool it in the near future so I'm keeping a close eye on this one, looking good so far :thumb:
