Scratch Build – In Progress Project: Blackwood (First Case Build) UPDATE!!
Discussion in 'Project Logs' started by DoctorWho05, 27 May 2011.
  1. DoctorWho05
    DoctorWho05 What's a Dremel?
    11 Jun 2007
    OK guys, finally got some real photos to show you. I started cutting and building yesterday so I can finally write my first Project Log! So here we go:
    Some angle I have in the vice prior to marking and cutting:
    Marking aluminum before cutting:
    Cutting aluminum angle:
    Filing the angle:
    Some pieces before getting drilled
    [​IMG] [​IMG]
    The old drill press. Used to be my grandfather's.
    Drilling holes:
    And finally, my first successful rivet!
    Hope you like what I've got so far. I will be working more on it today and I'll put up more pics tonight or over the weekend.
  2. Tenshi
    Tenshi What's a Dremel?
    12 May 2011
    Any 3D project?
  3. DoctorWho05
    11 Jun 2007
  4. KidMod-Southpaw
    28 Sep 2010
    That looks very nice!
  5. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That case, if pulled off effectively, should be goddamn Awesome. Good luck!
  6. DoctorWho05
    11 Jun 2007
    Project: Blackwood UPDATE
    Hey guys, thanks for the well-wishing! Here's some more work that I've done today
    First, a photo of the near-finished frame:
    Here I'm sanding down the rounded edges to make part of my makeshift bending brake:
    The assembled bending brake after the bending has been finished:
    Sorry I didn't take more photos of the bending process. It was really simple. I had a length of 1/16" x 1" flat stock aluminum. I screwed one end to the 2x4 and bent the metal around the wood using a block and a wood mallet. My dad provided an extra pair of hands :clap: The part that had the round edges was screwed down to the workbench so it wouldn't move. The metal was clamped to the wood at the other end to hold it down firmly while the end was bent.
    The bent pieces were riveted to the front of the frame:
    And the completed frame as it stands now!
  7. .//TuNdRa
    12 Feb 2011
    Looks a little like it's trying to flex back, but I'm sure some other helpful peeps could provide ideas on getting to behave. :3 Nicely done bit of metal-flexing, though.
  8. DoctorWho05
    11 Jun 2007
    Once I got it bent and riveted to the rest of the frame, I was confident it wasn't going to give me any trouble
  9. nathandanielmorris
    nathandanielmorris What's a Dremel?
    23 Jan 2011
    That 3D looks superb, fancy giving us some more insight into this? What are you using it for? Watercool or air? What hardware are you throwing in it etc.?
  10. DoctorWho05
    11 Jun 2007
    Well my intention is to make it into a gaming rig with water cooling. I have a decent rig right now, but I wanted to build something bigger and more impressive. I haven't completely settled on what I'm doing for hardware but I do know that I want an EVGA motherboard. I'm thinking of possible getting the P55 Cheesecake because it has a good balance of cost to features. It's made for gaming as is most EVGA boards. I want to do Corsair memory with it because I know first-hand how good their memory is. I plan on doing SLI with a few mid-range GTX cards, and an i5. Also, I am looking at doing a 1000W modular power supply. As I don't make much each week, all hardware components will be bought incrementally, so it will still be quite some time before this case gets its guts, but I still want to show off what I can do and hopefully somewhere down the road get some sponsorship.
  11. nathandanielmorris
    23 Jan 2011
    Sounds good, good luck, I'm sub'd.
  12. DoctorWho05
    11 Jun 2007
    UPDATE 2
    Hey guys, did a little more work on the case today. I added in the middle shelf/divider plate using a sheet of steel that I found in my neighbor's garage which happened to be almost perfect in length and perfect in width. I trimmed it with a pair of tin snips.
    I used some small pieces of left-over angle to use as mounting brackets in the corners to rivet the steel to.
    Here are my measured and cut mounts
    Here are the mounts riveted to the case before I put the steel in
    And photos of the end results!
    I'm still waiting for some sheet aluminum to come in that was ordered a few days ago. It was supposed to be here today, but I never got it...so hopefully it'll be here tomorrow. I plan on mounting the motherboard tray possibly tomorrow. I have a question: does any of you have any pointers on mounting the back panel after mounting the mobo tray? I know exactly where I want to put the tray but I'm not sure where exactly to mount the back panel in relationship to the mobo tray. I have a spare dead mATX motherboard i could use as a test fit i suppose.
  13. DoctorWho05
    11 Jun 2007
    Another question: How do I change the thread title to show an update like I see on everyone else's project logs? I'm trying to figure that part out so I can maybe get more views :\
  14. lamanl
    lamanl So little done, so much to do
    4 Nov 2009
    edit your first post
    than go advanced and there you can edit it
    your designe looks great
    and also a great start
    now lets see how it will become :D
    good luck
  15. DoctorWho05
    11 Jun 2007
    thanks for the tip and thanks for the comments. I'll put up more soon as I can...just waiting on the metal!
  16. DoctorWho05
    11 Jun 2007
    Ok time for another update! I mounted the motherboard tray yesterday and I think it came out pretty well. I tried double checking I have the positioning right by using a spare dead motherboard I had laying around. The tray still needs some modification for cable management, but I'm going to wait a little bit on that for now. I need to get more cutting wheels for the Dremel because all the cheesy ones that came with it all shattered. So without further adieu, the photos!
    one of the mounting brackets for the motherboard tray, mounted with countersunk 8-20 screws
    Top screw for the other mounting brace, mounted with pan head 8-20 machine screws
    Bottom screw for same bracket
    Tray mounted, seen from the back
    Tray mounted, seen from the left side of the case
    and last one: A better lit shot of the mounted motherboard tray before I put the second bracket in
    Let me know what you think! I have to do some tweaking of the sheet of steel to allow proper cable management later on. I'm also trying to figure out for when I get closer to completion, how I am going to mount the side panels. I don't exactly have the means of making those tabs that all factory-built chassis have. Any suggestions?
  17. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Awesome start! It's nice to see another project log virgin making their debut. I'll keep watch to see how you progress!
