PROJECT: Blinded Nightmare
Discussion in 'Project Logs' started by yuzi87, 25 Apr 2005.
  1. yuzi87
    yuzi87 What's a Dremel?
    25 Apr 2005
    Hi all started my new project on my tsunami dream silver, i built the comp i got now xmas 2003 with above mid range bits had it for a year then decided to do sumthing with it but was just a case of adding led fans and laser leds and spray painting case, as u can see from pic not that exciting.
    But now im going for the silent beast type of comp, all the bits ill be getting will be top of range and most of all silent im goin the fx55 route prob fx57 by the time i saved up for it
    So far i have taken all fans/holders out, taken the security switch out, took top ports out as i will get front usb panel, i have cut out front and rear fan honey combs added u channel grommet and rubber grommets for fan screws.
    after staring at my case for a while determined to change a lot more on it i decided i didnt like the top flap that had no use once i took the ports out so after deciding wat i cud put there i decided on modders mesh and a 120mm fan grill for extra cooling (supplied by mnpctech man ) i will somehow implement them into the top cut out as u will see as i do updates.
    more updates to come soon and ill draw up wat essentially i am hoping for my case to look like!
    btw i used to have a dremmel n it blew up so i did all this case with a 240v mains drill god know's at what rpm! i obliterated 18 of my old dremmel cutting discs, and even managed to rip out centre of all 5 of new cutting discs i got from mnpctech, finsihed al lthe cutting of with a 2mm burring bit lol, i had no paitence to wait n buy proper bits :rolleyes:
    My comp at the mo
    new case project
  2. yuzi87
    25 Apr 2005
    The next thing ill be doin wen i get some dosh is painting sum mesh looking for a piece of acrylic and with the fan grill turning it into something good for the cut out, i done a quick rough plan below (excuse the drawing)
  3. yuzi87
    25 Apr 2005
    not much of an update but i done a few little things to the case,
    first of all i wanted to know what color the power leds were so i connected a 12v 7ah battery to them but obvs this was 2 much for them and they blew up
    But luckily as i had taken the 2 bright blue leds out the front door i soldered both them to the wires, so hopefully wen its all up and running ill have blue leds to go with my theme,
  4. yuzi87
    25 Apr 2005
    2moro i should be finished spraying and ill post pics up, I recieved my black anodized pop rivets today, But unfortunatly they were to small for the holes i had to fix the grill onto so i had to use some standered larger ones but nevermind it doesnt look as bad as i thought it would and i mite think of a way to disguise them as well.
    A few more taster pics the best is yet to come!
  5. yuzi87
    25 Apr 2005
    Well I Finally got around to finishing my top cut out and it doesnt look to bad (ill try and get some better pics) and yea i no the rivet holes are a few mms out but to late now....although thinking about it i could make holes longer and use black rubber grommets to hide extra part of hole that would show..ill have to see
    also painted inside drive cages and side bar black... the paint job didnt go as well as i was hoping maybe i didnt have enough paitence but doesnt look to bad,
    ive recieved one of my packages i ordered for modding the front door all im waiting on now is a drill bit......this next mod is either gonna look really good or end up looking really bad........thats what u have to risk when it comes to modding i guess :p
    stay tuned for more updates!
  6. yuzi87
    25 Apr 2005
    Well Finally got round to extending the front intake holes in the door to improve airflow to front 120mm fan i know a lot of people didnt dare mess with their front door as its already a nice looking door and quite thick so i just had to go and do something to it :rolleyes: (it dont look the most perfect close up :sigh: but good enough) and i put a case wrap on to go with my theme.....should look really good when i get the blue ccfl and blue fans to shine out of it
    i also removed the comical purple/green pci bracket as ill be using black thumbscrews to secure any pci cards
    most of my case is now completed i will be adding some new feet to it and doing something with the inside floor of case and then its onto adding the hardware! :D
  7. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    I don't see the pics. But I'm sure it's nice what you've done so far.. :D
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Awesome work dude!!! Never seen red x's that detailed!!! Sorry. :D
  9. yuzi87
    25 Apr 2005
    dam geocities bandwith limit thing they should be back up within an hour.........anybody no any free sites i can host pictures on?
  10. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Http://www.Imageshack.us
  11. yuzi87
    25 Apr 2005
    pics fixed
    Cheers, pics are now fixed :rock:
  12. yuzi87
    25 Apr 2005
    ok so can u see um now ppl...? :sigh:
  13. mieleton
    mieleton What's a Dremel?
    15 Feb 2004
    The pics are visible now and they look pretty good. I like the idea of using the fan grill and mesh w/ acrylic. Also the front panel looks nice. The stock front panel on that case looks good, put with that skin it should go well with your theme. :)
    So, keep up the good work! :dremel:
  14. yuzi87
    25 Apr 2005
    im really looking forward to post more up with all the one coments ive had was expecting a bit more from these forums :eyebrow:
  15. webbyman
    webbyman Hax.
    7 Oct 2004
    Looking good :naughty:
  16. mr.X
    15 Mar 2005
    very nice job done. I like the case wrapping on the front. looking forward to see more.
    keep on moddin' :dremel:
  17. yuzi87
    25 Apr 2005
    As im gonan be having 2 raptors in enclosures and i have only got four 5"25 bays i was thinking to my self its gonna get pretty hot up there,
    so i found an old comp case drilled out the 5"25 drive bay cage and cut it down to fit in my new case just sanded it n now gonna prime it and spray it black to go with my theme also tonight ill be ordering my psu and mobo and sleeving kit :D
    Drive cage
    Cut and sanded
  18. wickyman
    wickyman What's a Dremel?
    7 May 2004
    Really nice looking case. Good work so far! I always appreciate a good mod, and this is a great mod! Fantastic man! Keep it up!
  19. yuzi87
    25 Apr 2005
    thanks ill post more pics soon
  20. mafia11671
    mafia11671 What's a Dremel?
    7 Feb 2005
    The cuts on the top and around the fanholes are slick and clean. Love the graphics on the case and use of the mesh and the fan grill. Curious how you are going to use the drive cage. VERY clean start.
    :thumb: :dremel: :thumb: :dremel:
    Mafia
