Scratch Build – In Progress Project: CircleButterfly (080403 New PSU comes with trouble)
Discussion in 'Project Logs' started by mr_carl, 3 Sep 2007.
  1. mr_carl
    mr_carl What's a Dremel?
    2 Jul 2007
    So after being a longtime lurker (about 4 years) I have finally come to my senses and decided to begin a work log.
    This is my first project so I´m supposed there will be some trile and error but I think it will come out great in the end if everything goes as I want it to.
    Anyway nuff said and I will let the images speak for themselves (with my comments off course ;) )
    The aluminium
    The circle
    circle side viev
    Circle wield (I didn't wield the aluminium)
    Front aluminium panels
    Image of front cutouts, and back engraving (probably)
    Traced the sketch
    engraving the contours so they wont disappear
    Powersupply :blah: (only 400w)
    Starting the build
    Cutting
    This is how far I got on one "blade"
    Allmost done
    the last bit to cut on this one
    getting a bit tired of cutting and makes some misstakes and breaks 2 blades in a row :duh:
    Finaly done
    More updates tomorrow
    now I have to go to bed.
  2. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    LOL sleep tight!!!! i might start my mod next summer to much stuff to do like school!!! will be watching:thumb:
  3. mr_carl
    2 Jul 2007
    [xXx] ãÇè_ƒr€áK Thanks for comment man, why not start a project now and just take it slow? :thumb:
    Anyway here is tonights update :D
    Starting with the little aluminium bit I cut out yesterday
    Drilled some holes
    and some more holes
    they match up :clap:
    Bought a new tool today :clap:
    And I used it to :D
    The result
    I guess you all can figure out what I´m about to do with this
    Continuing with the engraving
    And finally I´m done with the engraved guides
    and a closeup of the engravings.
    Well thats all for today folks
    and now I´m off to bed ones again :clap:
    Good night, Sleep tight.
  4. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    very sexy engraving!
    make sure u use the zerotherm butterfly cpu cooler
  5. mr_carl
    2 Jul 2007
    Thanks Zhangmaster, I´m strongley thinking about that zerotherm butterfly cooler it would really look good indeed but on the other hand I really whant to use watercooling and at the moment I relly dont konw wht to choose.
  6. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    nice engraving work :thumb:
  7. mr_carl
    2 Jul 2007
    Thanks Supra55.
    So no upgrade today because I have been on a Logitech resellers event in Stockholm today and checked out some of the new stuff coming from them and I just have to say that I really like the new MX Air mouse and I really want one, it worked really well. I also tried the new Wave keyboard and looked at the VX Nano and some of the old stuff like Dinovo Edge and Harmony1000.
    I´m a litle disappointedly at the G9 mouse I thought it would be something really cool for gamers but I wont change my MX Revolution for that.
    Anyway It has been a really nice day and some more updates will come tomorrow.
    Good night
  8. ComputerKing
    8 Sep 2006
    WOWO so nice work really! Well done, Can't wait to see more. Good job..
    Good luck.
  9. Jipa
    5 Feb 2004
    Good job with the engravings. Why did you use the Ferm and cutting disks to cut straight lines? I don't get it, hacksaw is sooooooooOoOoOoOO much better in straight lines. No blades wasted and the job gets done in no time.
  10. mr_carl
    2 Jul 2007
    ComputerKing: Thanks man more updates coming you're way now :D
    Jipa: Thanks, well the simple answer on you´re question is "I didn't have one at the moment :wallbash:" Just bought one yesterday but I haven´t used it just jet, because it sounds allot and I don´t thing my neighbor´s would like the sound of me cutting stuff at one in the morning :naughty: all thou I don't mind doing it.
  11. mr_carl
    2 Jul 2007
    So on with todays update.
    I decided to take some pictures of my new hardware now that my Motherboard has come.
    It´s an ASUS P5N32-SLI, I changed my Stiker Extreme for this one, I really liked the Looks of the stiker but I only had problems with it so I dcided to try this one instead and when I´m done with this I just hav to get the Maximus Blits, or what it´s called, but for now this will have to do.
    So here is the hardware all together, unfortunately this wont go in the Circle because I only have a 400W power supply in there.
    With the super case :jawdrop: I´m using for this one at the moment
    Just the case, off course I´m going to mod it, but thats my next project´m starting when Circle Butterfly is almost done :D
    Motherboard in Circle. Looks really ncie
    150GB raptor
    4GB memory
    Graphixcards
    another view
    Now what is this box??
    Oh it´s my 700w Recommended by Bit-Tech Tagan modular power supply :clap:
    Anyhow nuff with hardware and on with moddingware:eyebrow:
    So I needed a good circle in the right sice, and I looked everywhere till I found this and I traced it :thumb:
    Starting the cutting of my little circle... ore drilling actually
    more drilling....
    Halfway there
    And I´m done drilling :thumb: now this was a really long proses and I have so much more to drill:duh:
    Cutting
    And it´s´finally free
    It fits like a glove:thumb:
    Well thats all for today folks, now I´m off to bed as usually.
    Tomorrow I will cut the big circle with my new hacksaw:clap:
    Good night
  12. ComputerKing
    8 Sep 2006
    WOW! So amazing, HOT! SOO nice work really, I love it and I love your fancy hardware :) can't wait to see more.
    Good luck.
  13. mr_carl
    2 Jul 2007
    Project CircleButterfly update 070906
    ComputerKing Thanx ones again man I really like you're positive spirit, keep it up.
    So I didn´t have allot of time to do allot today ore actually the stuff I did took allot more time than planed so just a little update today:)
    So I cut the fron Circle with my new saw today and it vent very well thnkt because I have never used one before, it is´t perfect but I can change that.
    It´s free but not good have to fix it
    Drilled some holes
    And cut the peaces
    All done :D
    As I don´t have a grinder or something like that I had to make one
    Now some more drilling
    all done with the markings
    and starting to make some holes
    Halfway there
    and I´m done :D
    thats all I had time fore today, tomorrow I will cutt these parts away and start on the front panel I hope, my drill is starting to get a bit bad and does´t work as well as it used to.
    Night night
  14. Supra55
    10 Oct 2006
    Well you sure have a very neat style ima watch this thread, subscribed :thumb:
  15. ComputerKing
    8 Sep 2006
    Dude Really this is Kciakss work! Dam, This is so nice. Sexy work really! Can't can't wait to see more more work. WOW! I like the flower.
    Good luck.
  16. mr_carl
    2 Jul 2007
    thanks dudes I really appreciate your´e comment´s and here is a little update of what I did last night, it´s not much but I started really late so I did´t have allot of time or energy to do so much and off course I forgot my camera:wallbash: so I had to use my mobile phone camera so it´s not the best quality images today. Anyway here is the update.
    So I started to cut the aluminium and with all the holes it does´t take to long.
    and I´m done with the cutting
    and a little closeup
    and in the circle
    thats all for now, more coming soon.
  17. mr_carl
    2 Jul 2007
    So here is todays update.
    It was a good day until the end, you will see.
    But first some images from yesterday, I forgot my camera in workshop yesterday, so here is that update.
    Setting up for some grinding,
    and this is how it turns out, I will have to do the narrow parts by hand with a file
    I can´t do more than this with my tools at the moment, and all my grinding rolls are out
    this is all thats left:waah: no more grinding untill I go shop
    I started with grinding out some guides so that my drill wont go all over the place
    It doesetn look verry good I know but here its all done
    Then I started to drill some holes, the guides worked pretty well
    drilled allot of holes, I someone knows a better way of doing this without a saw please tell me now because I have alot more holes to do
    now I start to cut away those peaces
    but it really takes allot of time and those cutting disks are just all over the place, with this peas I used about 5 cutting disks, but I was a bit tired so I will blame on that :D
    So when I had done this I tough why not try my power supply :thumb: I haven't done that yet, just opened it and this is what happened
    I short circuit the hole room and leaved this marks :wallbash:
    I feel like such a NOOB:duh: trying my power supply and not moving the aluminium.:duh::wallbash:
    Anyway thats all for today
    Good night
  18. FR34K
    FR34K What's a Dremel?
    1 Feb 2007
    you might wanna look into getting an actual grinding wheel instead of using those replaceable sanders...
    for example: the little grinder in this...can't seem to find one on it's own(usually come in a set)
    :dremel::thumb:
  19. mr_carl
    2 Jul 2007
    So I had one of those grinding wheels and this is my result with it
    the aluminium just get stuck on there and then it´s useless, maby i´m doing something very wrong??
    anyway I have also had some time to star to cut up the front plate enjoy:dremel:
  20. Guest-23315
    Guest-23315 Guest
    Thats some damn good work.
