Case Mod - In Progress Project: Clean
Discussion in 'Project Logs' started by domthecondom, 27 Jun 2010.
  1. domthecondom
    domthecondom Noob Modder
    27 Jun 2010
    cool HPV500. have you got any photos you could send me? Can I ask what you googled?
    Anyway guys the Sound card is currently being sprayed :)
  2. Chanc3
    Chanc3 New Member
    22 Jun 2010
    Looking good. Love white cases, will be watching!
  3. domthecondom
    27 Jun 2010
    Cheers Chanc3....hopefully it will pick up again
  4. domthecondom
    27 Jun 2010
    Well I have sent of some Thumbscrews to be anodized blue and some mesh fanguards to be sprayed
  5. domthecondom
    27 Jun 2010
    The Soundcard finally arrived :) looks good :)
    Thanks again Tom @ chilledpc.co.uk
    Got My Intel SSD today aswell 160GB :)
    Here is a quick benchmark in AS SSD. What other benchies should I run?
  6. ringoiom
    ringoiom Member
    20 Jul 2010
    Understatement........ :brrr::clap:
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    That soundcard looks amazing, no lie
    I've never seen a soundcard that looked that damn good
  8. domthecondom
    27 Jun 2010
    :blush: Cheers guys.
    Should have another tiny weeny update tomorrow.
    want to install windows 7 on the SSD but can't find the disk, I think its packed away in a box ready to move house but we don't have a move in date yet :grr:. On saturday I will be driving to the Storage place and unpack the box :thumb:
  9. Unicorn
    25 Jul 2006
    Did you have the shield of that Xonar anodised that colour? That looks fantastic! I have to say, for only two pages into the project you really have impressed me... I may even subscribe to this. Well done so far and good luck with the rest of it! :thumb:
  10. Infiniti
    Infiniti i modded the wheel!
    3 May 2009
    love the build where u get that seeving from....pretty ace work :D
  11. Tangster
    23 May 2009
    You should powder the SSD as well. Very nice looking build.
  12. domthecondom
    27 Jun 2010
    Yes, the original was black. :) I am still in the process of moving out, so only small updates can be done at the moment. Cheers dude :)
    The sleaving is from http://www.chilledpc.co.uk :) Tom that owns chilledpc has his own selection of sleaving and his sleaving is very dense weave. :) check it out dude.
    I would love to get the SSD done, but I don't know what material the casing is. hmpf Maybe Anodize it blue aswell? But then my Storage drives would look out of place and I don't want to risk them being broken
  13. Kovoet
    Kovoet New Member
    26 Aug 2009
    Looking damn fine and love what you did to the PSU
  14. domthecondom
    27 Jun 2010
    Thank you very much. Tom said it was a pain the the bum to do as the Enermax has got quite a rough surface! I am happy with how it came out! :rock::clap:
  15. domthecondom
    27 Jun 2010
    Got another package today :)
    5 Enermax Clusters second hand of Overstockers MM.
    Need 3 more anybody got any for sell? :p
    They are VERY nice fans yummy :)
    The white light should go well inside my case :) there is a switch on the fans to turn the LED off :) nice touch!
    Now is the question, do i leave the white braid on? or do i use the blue and white braid?
    hmpf what do you lot think I should do?
  16. PabloFunky
    PabloFunky New Member
    19 Sep 2010
    Only just seen this build,
    As you know my build is same blue/white colour scheme.
    But my hat goes off to you, you really are doing ace job powdering and painting everything.
    Can i be cheeky, ask where you got the blue/white braid from.
    Also thanks for tip on psu, wasnt sure if it could be powdered.
    So not only have you done so far an ace build, youve helped out the Funky, with his queries also.
    Win Win.
    Soundcard looks ace, however, when its in pc, you wont really see it, which is annoying.
  17. domthecondom
    27 Jun 2010
    Well hopefully once I have some lighting inside the PC you will be able to See it ;)
  18. PabloFunky
    19 Sep 2010
    Thanks matey, the side of the souncard is visible (have same one), seems we have same components.... great minds he he.
    Are you going to watercool?, ive got them d5 ek tops in white, they are really cool with colour sceme.
  19. bulldogjeff
    2 Mar 2010
    Coming along nicely, the blue on the sound card is gorgeous:thumb:
  20. Matticus
    Matticus ...
    23 Feb 2008
    Loving the colours, the sound card and power supply look amazing, and any lian li only gets better when its white.
    I have been eying up some chilled PC sleeving for a while, it seems the most dense weave you can get without going MDPC-X. Can I ask what sizes you got for the fans and the sata cables? I am going to assume 4mm for the small fan sleeving and 10mm for the sata? Also what size and ratio heatshrink did you get? Cheers
