Scratch Build – In Progress Project; Command & Conquer GDI Base Station
Discussion in 'Project Logs' started by Frenkie, 25 Sep 2008.
  1. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    WOW.
    The quality of your work is outstanding. You sure have the technique and the eye for detail needed to take 1st place, I will be keeping an eye on this one.
    :clap:
  2. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    I have to agree, it's coming on so well. Keep up the good work.
  3. DuVeL
    DuVeL What's a Dremel?
    4 Apr 2007
    Now that's beer! :rock: :thumb:
    Good luck with the details.
    How much time to the end of the competition?
  4. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    I have until Dec 12, so that's more then enough time for me to end this project.
    Just finished the crane-vehicle with the grasping arm.
    Got a funny idea; the container that will be in the front yard, will light up with pulsing green glow,
    as if it contains some kind of radioactive stuff.
    The 3 containers in the back will have no lights as if the're empty. :D
  5. Frenkie
    3 Jul 2006
    Started sanding the case, to prep it for painting.
    Hmm, this piece was irritating me all the time.
    So, I cut it out.
    And inserted a nice new piece.
    After painting, it wont stick out like a sore thumb any more.
  6. Frenkie
    3 Jul 2006
    Mounted the two sidepanels with rivets and construction-glue.
    Overview with the top on it.
    View from the other side.
    In the game, when the vehicle is folded out, we see 4 hydraulic feet on the side.
    Lets try to make that too.
    First try-out in paper.... way to square. Rejected.
    Second try-out, now with more elevated sides.
    Same design, now in cardboard layout.
    The small feet is also made like this.
    Hmmmm.... first test with the actual case-side panel.
    Nop, this is way to straight, have to redo my homework.... :(
  7. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    nice work done with the cardboard the details i love it good job man :clap:
  8. Guest-23315
    Guest-23315 Guest
    This looks fantastic!
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    I can't see any of these pictures :(
  10. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    Wow
    That looks awesome :jawdrop:
    I love the C&C theme.
  11. Frenkie
    3 Jul 2006
    Made another 4 legs, this time in polystyreen.
    And this is how it looks like after assembling with model-glue.
    To attach them to the case ( and make it able to disassemble for transport ), I thought
    of this. A M6 nut and a short bolt.
    I am glueing the nut into the hollow leg, then attach it to the case with the bolt.
    This is how the leg looks like after a spot of paint and a sticker.
    Ofcourse that times 4.
    Lets get them on, first drill a hole.
    Then stick the bolt through it from the underside.
    Then simple screw the leg onto it.
    Twice per side.
    Just like in the game.
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    I still can't see the pics, and without pics this is a little disappointing...
  13. Frenkie
    3 Jul 2006
    Then you should fix something in your computer, the rest of the world can see all of it.
  14. phenoptix
    16 Aug 2006
    Even I can see them and my computer is rubbish!
    Frenkie, those vents should be octagonal- I thought you were a details man! :p
  15. Frenkie
    3 Jul 2006
    Haha, silly man. You see octagonal, because the game doesnt draw circles. Trust me, the're supposed to be round! :D
  16. phenoptix
    16 Aug 2006
    I'll trust you on that. Now a question, what's that Grolsch like? Is it a dark beer?
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hmm, I can see them via a proxy. Peculiar.
  18. DuVeL
    4 Apr 2007
    That one he had on his picture; yes. It's one of the season beers from Grolsch
    I reckon Frenkie normally drinks the light green bottles, the same as I drink;
  19. phenoptix
    16 Aug 2006
    In the UK it's always best to look for the "swing top" Grolsch, swing tops are imported. Otherwise (in the UK) you're drinking pish that's brewed under license by Coors in Burton on Trent. Do Grolsch do many seasonal beers? It's not something we see much of here.
    Anyway back to topic. Update please.
  20. Frenkie
    3 Jul 2006
    Sprayed the top with spray-filler.
    With first coat, after this a light sanding then second coat.
    For the third coat I found this special structure paint ( english transl.? )
    On these pictures the color seems to be off,but the structure is awesome. Close-up of
    that structure, it almost seems like spraying sand.
    Also sprayed the inside of the case, dull-black. Yes, also the P1 mobo :)
    From the other side.
    For the front and rear, I used this special black-metallic paint.
    looks a bit like Hammerite, also a bit special IMO.
    Maybe the case looks like its coming to an end, but I have several suprises waiting for you all. ;)
