As you can see I’m new at these bands although reading your forum for some months. I’m from Portugal and my Name is (just like my nick) Daniel Warning Lots of Photos.. --------------------------------------------------------------- For the year 2004 I developed a custom built case called Cubic2004 which you can see the full log at HERE - Cubic 2004 A picture of Cubic2004 Click to enlarge Please feel free to comment cubic 2004 at the original log site. ---------------------------------------------------------------- Well let’s get to business… For the year 2005 ill use a new case.. Code Name: CUBIC 2005 Deadline – 31/12/04 IT AS BEGAN - Cubic 2005 I’ll use the interior of a Shuttle…. Click to enlarge Build Support In order to use WC on the case (which is Amd, but as a layout as Pentium) I had to build a new support. Click to enlarge Click to enlarge I think it went just fine.. Next design a front for the case Click to enlarge I pretended to use thi from the shuttle.. Click to enlarge The hard part was the front layout to be exactly correct.. Click to enlarge Click to enlarge Face Plate for de Dvd/Rw Click to enlarge The button i had to sandpaper in order to the light to diffuse better.. Click to enlarge Test Light after sanding Click to enlarge
Giving live to power and reset switch Click to enlarge Building Left Side Click to enlarge Work in progress.. What do you think till now ?? Nice or just crap ??... Greetings from Portugal.
First of all, welcome to the forums. And that is a nice project you have there Can't wait to see more BTW your enlish seems fine to me. (w00t!!! 100th post , wait I was gonna post my first project log with it oh well I'll get to that later)
Custom waterblock hold-down? That's awesome! I knew it would be good before I started even reading it somehow... I was right Great work so far, keep it up!
That looks really good!!! Do really like the clean and nice design! Keep the great work up, and give us more great updates!
tanks for the comments.. I’ll keep actualizing the mod log... the panels were laser cuted where in Portugal... (jazzle > you got pm)
What kind of material did ya use? It looks like black plexiglass or something. And how did u connect the diffrent parts together? Awsome looking mod btw. Really looking nice.
Yes its black Plexiglas’s.. Its connected with a glue called Turbo2.. Other parts were cut to fit really tight just pure pressure on it The Plexiglas’s just at the outside of power and reset button it’s by pressure… it fit’s REALLY tight
Ok. Wc stuff.. Plexiglas’s for WC Resevoir The illumination of the case will be White... So.. With led´s nothing better than white Plexiglas’s.. still with some paper and not clean Click to enlarge
sorry the triple post Bringing the power tools.. Click to Enlarge ZZZZRIIIIIIIRRRRRGGGG Click to Enlarge Opening size 1/8 Click to Enlarge 1/8 for conector (the front seems all scratched, but it´s still the protective paper.) Click to Enlarge
