hello everybody this is my first post and I hope I'm not going to make too much confusion...well ......... let’s start. Project Delta was born for passion that I have of this formidable car since childhood...the lancia delta Integrale won 6 consecutive world titles (87-92) becoming legend. it' not a car.....it's a legend Specs: Cpu: Ryzen 2700x Motherboard: Asus x470 crosshair WI fi Ram: Gskill 3200 c14 8x2gb Scheda video: Radeon vii SSD : Wd black 750 nvme 500gb Alimentatore: Seasonic 1000 watt titanium Case: Cosmos c700p X2 Reservoir swiftech maelstrom X2Pump d5 laing/xylem swiftech Fitting barrow for hard tubing Fitting ekwb soft tubing Waterblock cpu swiftech apogee skf prestige Waterblock gpu ek-vector Radeon vii rgb nickel+plexi Radiatori X2 360 pe ekwb I want to thank Swiftech for sponsoring I want also to thank Hydra for the combs Thanks also to my group the Italian extreme modders for the support
I started to unmount completely pc. Excuse me for image's quality. After I created a plane for pumps that will be detached from the tanks...unfortunately when I maked the photo the pumps of Swiftech were in shipment and I don't want to mention other brand.
Then, with the laser cut, I created small separate stripes of the colors of the delta lancia for the front and after I glued them and I warmed them by taking the shape of the front.
Here there is the partially finished front and the first laser logo on the back panel, partially completed.... I forgot to emphasize that I had already painted the pieces with white colour.
Then I created a cover psu and finally the swiftech products arrived. I did various tests, because they were very large tanks. I also created an internal panel for reservoir. I haven't a picture of the definitive but this is very close to the final.
I continued with the loop tests and when I finished them, I started to test the plant under the cover psu ...
I began to put some details; for example the elephant of lancia delta that could not miss. Even sponsors on the back panel have been completed.
After I created an external frame where I was going to put the laurels with the annals and a tag of the rally brand. It was a grueling job because the pieces were really really small.
I installed lights, I finished everything and here there are final photos...I hope you like this mod and I apologize again for the few detailed work log, I promise that the next will be more precise and detailed.
[QUOTE = "TodMod, post: 4660325, membro: 872729"] fantastica mod congratulazioni bro !!! [/ QUOTE] Grazie a todmod
