Project: Entropy
Discussion in 'Project Logs' started by thingamajig, 6 Jan 2007.
  1. thingamajig
    thingamajig What's a Dremel?
    29 Nov 2005
    en·tro·py -- A measure of the disorder or randomness in a closed system.
    I hope this to be my first complete work log. I've posted other work logs on other forums, in the past, but never completed it for one reason or the other. I'm not planning anything over the top; just a couple of clean mods to make my case mine.
    I really enjoy reading other peoples project logs where they talk about their mistakes as well as their successes. Everyone makes mistakes they are part of the project so let's see them!!
    I chose the silver SILVERSTONE TEMJIN SST-TJ02SW case as my canvas. My original plan was to get everything except the front bezel powder coated a deep red, but I also wanted one of one of MNPCTECH's 120mm Machined Billet Blowholes so I decided to skip the powder coating at this time. :cry
    Now for the Mods. I'll let the pictures do most of the talking.
    Access Hole To Hide PSU Wires
    I used the mini-me version of mnpctech's 120mm punch to pop 3 7/8" holes into to the side then filed down the peaks to make a nice oval to route cables.
    120mm Blowhole
    Remember the old adage "Measure Twice - Cut Once" well they should also have a "make sure the panel is oriented correctly" before you measure.
    I had initially decided to center the hole along the complete depth of the case (bezel and chassis), but had the top panel installed backwards. So...I started to cut my hole and suddenly realized that my hole was off by a 1.5". After a lot of swearing and some WoW I adjusted the hole so that the billet aluminum would cover up my mistake.
    Handles
    Strangely enough this is the smallest case that I have, but it's also the heaviest. I decided to borrow my case handles from other pc until I can order a replacement.
    Yes I know it's all mnpctech products so far, but you can't deny that he makes some awesome eye-candy.
    Comments Welcome.
  2. precision
    precision What's a Dremel?
    1 Jan 2007
    Looking good so far :thumb: Especially like the idea of the psu wires hiding hole, are the handles custom made?
  3. Napster
    Napster What's a Dremel?
    9 Nov 2004
    yeah i love it to.. wish that that tool that u use to get the holes was in the size of 76 and 116=) keep up the work=) :thumb:
  4. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    Looks good, keep it up, nice psu hiding hole very professional, ncie job tho hope to see more!
  5. WiK1d
    WiK1d What's a Dremel?
    16 May 2006
    I think they are from MNPCTECH...
  6. thingamajig
    29 Nov 2005
    Yep, they're from MNPCTECH . He is out of them currently, but I heard that he will be making more so I decided I could steal them from my other case in the mean time.
