Case Mod - In Progress Project: First Mod (Exhaust Fans 25/02/08)
Discussion in 'Project Logs' started by craig_h, 29 Jan 2008.
  1. craig_h
    craig_h What's a Dremel?
    29 Jan 2008
    Bead blasted, it is not has harsh as sand blasting but gets the chassis smooth.
  2. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
  3. craig_h
    29 Jan 2008
    I used an 80mm fan on the front because a 120mm wouldn't fit because of the step in the case. The case is quite small but its big enough for what i want.
  4. kenshinryu
    kenshinryu has a flavor...
    25 Feb 2008
    Looking really good so far. No worthwhile constructive criticism to add, just thought I'd drop some props :3.
  5. craig_h
    29 Jan 2008
    Thanks for the comments. I should have an update to post up tonight.
  6. craig_h
    29 Jan 2008
    I have been concentrating on getting the exhaust fans mounted onto the case. I will then make a grill to cover the fans.
    Fans mounted onto the case
    Plexi cut with dremel. I have cut the piece bigger than needed because i didn't want to mess it up and i will sand it down when i polish the edges.
    Any comments and suggestions welcome.
  7. SaII
    SaII What's a Dremel?
    7 Jun 2006
    lot'o'fans
    planned an air flow chart yet :D
  8. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    On the front panel, where the power and led indicators are, is a recessed section, that goes down and around the lower part of the facia (front panel), you could get some black plexi and template the shape, then bump out your buttons and led indicators or add some led housings say in chrome, this would compliment both the buttons , the blowhole and the extreme orange color, I quite like the color chosen, but its an extreme color that needs to be broken down by something, maybe that black plexi piece would do it.
    Seth
