Scratch Build – In Progress Project: Framed - 4PC Test System
Discussion in 'Project Logs' started by TheGreatSatan, 15 May 2008.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Here's something I've wanted to do for a long time. I'm working on a 4 PC system test machine. I will be putting 4 complete computer systems in one case. There will be a complete AMD XP and X2 dual core system, also there will be a complete P4 and Intel Core Duo system. Each will have their own Hard Drive, PSU and power button. They will all be able to use one LCD mounted on top. I will just need to adjust the plugs on the back and boot up the system I want to use. Obviously no normal case can hold this many parts so I will be using an organizer I recently bought.
    Here's kinda what it'll look like
    First I have to cut these off:
  2. TheGreatSatan
    5 Aug 2005
    Update: All 4 PC's will use the same keyboard, mouse and monitor via a KVM switch
  3. Jipa
    5 Feb 2004
    That organizer is a lovely piece of kit, I like shiny things. Keeping an eye on this, weirdo cases are always nice to see! What kind of testing do you do with all the rigs?
  4. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    hmm are you gonna put acrylic on the outside or keep the chrome look going?
  5. TheGreatSatan
    5 Aug 2005
    I usually test ram and HD's. And I'll be able to have this whole thing on wheels too!
    So begins the fun!
    That was easy
    And they're off!
    Then comes the plexi fitting.
    There's one side. I attached it with rivets.
    I'll wait to attach the other side till later. I first need to mount the components on plexi "drawers" and slide them in. At the end I will attach the other side panel with screws.
  6. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    hmm interesting...
    are the systems you are running powerful, maybe you dont need to use 4 power supplies. i think i saw a two systems in 1 case computer that used just 1 power supply.
  7. TheGreatSatan
    5 Aug 2005
    I think it would be easier if they all had their own, especially with all the connections each will have to make.
    I found this old topper to my Mother-Bored PC to help with my intake.
    I slid it into the bottom and since cold air settles on the bottom it'll be a primo place to have air sucked up and in.
  8. hotdog
    hotdog What's a Dremel?
    5 Feb 2007
    Dude that will be an awesome mod. I sometimes see things at the stores and say to myself that would make a nice mod part or case. Even the chrome trash cans....lol. Good luck!! :thumb:
  9. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    subscribed... should try this meself with a few systems I've got about...
  10. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Liking it dude! Intuitive use of furniture :p
    Be sure to fit a good air filter on those fans at the bottom. Otherwise you could end up with the worlds most advanced Dyson. :p
    In your 4th picture of your second post, I see a model bus...? That could easily turn into a brilliant mod!
  11. okapi
    okapi What's a zebra?
    4 Jan 2008
    That is a mod! Eagle 5 - Spaceballs PC
  12. modgodtanvir
    28 May 2007
    SPACEBALLS! Thats brilliant!
    Barfolemew!
    Moving on...
    I just had the idea of:
    Drawer slides for your motherboards... I suppose it beats having to remove the mobo completely every time you want to change a small part...
  13. TheGreatSatan
    5 Aug 2005
    It's an awfully light organizer. If I added drawer sides to it and wanted to add memory, I think the force to push memory into place would knock this thing over.
    I'm using the Athlon 64 X2 BE-2300 which runs at 1.9GHz and uses only 45 Watts and not the normal 65 watts. The motherboard is AM2 and AM2+ compatible.
    I don't have the dual Core Intel system yet.
    For AMD single core, I think I have the 2800+, but I'll have to check
    The Intel single core will be a Pentium 4 running at 1.7GHz
    All the computers will have their own power supplies, DVD drives, hard drives (Windows XP Pro) and 1 Gig of memory. As of now I will be using onboard video and sound, but that might change later. On Monday or Tuesday I'm going to Lowes to have the real thick plexi cut out for me for each of the landings.
  14. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    TGS nice to see you modding still
    great find you've got there like a custom server rack really
    does the height between rails give you enough space for GPU / PCI cards etc?
  15. TheGreatSatan
    5 Aug 2005
    I'm not going to be needing cards because I'm using onboard audio and video and won't be using any cards. But I think it will fit......
  16. TheGreatSatan
    5 Aug 2005
    Alright, the Intel dual core will be a plain jane E2140. That's all I actually need anyway.
    Here's a rough idea of the front.
  17. yakyb
    10 Oct 2006
    out of interest what do you plan on testing with it?
    i would love one of these thing holding my server/developmentbox/gaming computer/general use computer all in one place as i say much like a server rack
  18. TheGreatSatan
    5 Aug 2005
    I usually test RAM, HD's, cards, the works.
    I got the plexi today, the real thick stuff. So thick, that Lowes was unable to cut it for me.
  19. TheGreatSatan
    5 Aug 2005
    So here's the plexi and my how I'll cut it tonight.
    I'll use which ever works. I'm waiting for the other mobo's to arrive.
    Here's the RAM for the dual core mobo's, 2 sticks, 1GB each
    And the RAM for the single core Mobo's, 2 sticks for each, 1GB total
    I have lots of drives available
    And lots of PSU's
  20. TheGreatSatan
    5 Aug 2005
    Has anyone installed XP on an external drive before? I'm thing of using an external drive on my Framed project, so when I boot up what ever system I'm using, I could just plug in the external drive. Also, would this not be a good idea because of all the different motherboards and their individual drivers?
