Scratch Build – In Progress Project: FrozenCPU: Billet Pron Bench; Sponsored by CORSAIR
Discussion in 'Project Logs' started by mnpctech, 18 Jan 2013.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    @Darkened, honored to have your drop by and comment! I can't wait to see your build finished too! :clap:
    @Cheaps, I haven't been able to find cast acrylic tubing, probably just not looking hard enough tho...lol :worried:
  2. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    i dont believe they make cast aclylic tube, that would mean the mold would have to be minimum of 3 to 4 meters long. they only exist for extremely large diameters. here is the link to one of the major tube manufacturors tube brochure: http://www.plexiglas-shop.com/pdfs/en/211-12-PLEXIGLAS-Tubes-Rods-en.pdf
    good luck finding a fitting that fits on a 300mm tube :p
  3. mnpctech
    21 Apr 2003
    I discovered that as well, Thank you :thumb:
    Silicone Fill Tubing, insert into Primochill .5" OD acrylic tubing.
    Dip the Silicone Fill Tubing in Dish Soap water
    http://mnpctech.com/pc-computer-alphacool-ek-bitspower-hardwarelabs-heatkiller-liquid-cooling/acrylic-tubing-and-pipe-reamer.html
    Tubing Reamer / Deburr for Rigid Acrylic Tubing, used for Hardlined Liquid loops in Pcs
    Insert Silicone Fill tubing into the 1/2" Primochill Acrylic tube before heating the Tubing.
    Hold the tubing around 4" above the heat, and keep rotating the Acrylic tubing over the heat.
    I made Acrylic Tubing Bending Jig, from Acrylic!
    I made it from .5" Clear Acrylic scrap from the workshop. For the bends, I used our 1-3/4" & 1" Billet PC Case Feet for two different size bends.
    Placing .5" Primochill tubing along channel and 1" case foot, to create 90 degree bend.
    1" inside bend
    Primochill .5" acrylic tubing for EK Terminal Bridge
  4. Nexxo
    23 Oct 2001
    Sweet tubing! Thanks for the detailed information and pictures on the tubing connectors and the bending techniques. :thumb:
  5. mnpctech
    21 Apr 2003
    Thanks Nexxo! and good to hear from you again :hip:
  6. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Flange Adaptors getting down to 1/4 " thread is hard part :D
    Nice smooth bends Bill :clap:
  7. mnpctech
    21 Apr 2003
    Thank you Big_malc! ..and I imagine Cast Acrylic not bending as easily as Extruded...
  8. 666painkiller
    666painkiller If only....
    23 Jun 2010
    stunning......so much skill
  9. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Very, very precise, gorgeous bends on the tubing, bill!
  10. mnpctech
    21 Apr 2003
    Thank you for the comments guys! the 480 Radiators and CPU block arrived from frozen, so I should have another update of the progress soon!
  11. mnpctech
    21 Apr 2003
    Still waiting on cooling fans and additional Fittings to arrive from frozen. I've also changed direction and making slots in the top tray. I got caught up in the look of tubing wrapping around the edges of MB, but my better judgement is telling me to add slots in the tray, so you can insert acrylic lines into the Aqualis inlet/outlets directly from above, eliminating any future hassle when swapping out hardware.
  12. Cheapskate
    13 May 2007
    Is it because the disconnects would all be over a million watt power supply?
  13. mnpctech
    21 Apr 2003
    nah, just easier for accessing everything over long haul.
  14. mnpctech
    21 Apr 2003
    was going thru builder withdrawal after spending past several weeks learning how to build and operate our new website while waiting for hardware and fittings to arrive. Heres the update pics from the weekend after installing all of the hardware, including SSD, psu and power connections. as sexy as that loop looked, wrapped under the MB, the practicality gremlins told me to revise the motherboard plate with opening over primochill ghosts revolver fittings. This will make it easier to install / uninstall the rigid hard line tubing to cpu and gpu loop.
    BIG Thank you to Corsair in sponsoring this project
    Revised the motherboard plate with opening over primochill ghosts revolver fittings.
    Drain Valve, located behind front cover.
    next stage is mounting the two 480 radiators
  15. Cheapskate
    13 May 2007
    Seems to be a new slot on the other side too...
    The EVGA logo on the heatsink drives me crazy. I keep thinking there's a pair of pliers on the board.
  16. siliconfanatic
    10 Sep 2012
    Sleep-modding now, cheaps? :D
    good to see you're not dead, bill!
  17. mnpctech
    21 Apr 2003
    @cheap, agreed..lol
    @silicone, just keepin busy..ha!
    and MERRY CHRISTMAS to you and your families!
    just posted final episode for MZ-1 PC build
    Marcos_Viegas likes this.
  18. bulldogjeff
    2 Mar 2010
    I haven't looked in on this one for a while..Looking seriously good. The bending on the tubing is wicked. Some very tight turns... top modding. gonna be one sweet mod when it's finished.
  19. mnpctech
    21 Apr 2003
    Good to hear from you again bulldog! I've revised and simplified the layout for the rigid tubing, for easier access, going into shop today to do some bending :D
  20. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Damn... starting to look epic with the hardware and liquid cooling beezkneez in this beast.
    I must agree what was said earlier tho, the 90° 24pin makes for easier cable management, but personally I think it would've looked nicer in this build if you had it stand up like the other connectors.
    Great none the less!! :)
    Can't wait to see what this looks like in the next update!
    Keep up the great work Mr. Owen. :thumb::thumb::thumb:
