nice man! what was that plexi? 3mm? acryl? polykarbonat? and was it hard to cut? im thinking samestyle
Project: Gigi's micro-custom-plexi-case cd-rom cover cd-rom out cool look in the front is panel with echted gigis pages red underlight together with blue ) red all all WIND TUNEL hot air and bending... gluing to side eletrical circuit wind tunel-lighted lets get in
This is one SCHWEEEEET case!!! idea: why not bring the led of cd-rw drive to the cd-rw's customized plexi panel and etch something on it too?
Wow looks great. Need to sand and generally clean up the cuts. It might just be me not paying attention properly/crap pictures. Looks awesome tho. You should be proud of yourself.
some x-tra fotoz blicking regulator in action(cant see on the foto, video will be avaible soon extrernal hdd conecting.. conect to case, and transfering data to main hdd my hp318 cant catch everything...
1/2 finall (day-light) fotos front/side/back/light/.... btw : how can i edit the thread title? next time will be part2 and night-shots
i love how you just made the circular cutting tool, simply because you didn't have one. now that's a sign of a true modder! =) you said about controlling the led's with the parallel port, i'm assuming you're making some small VB program (or whatever language) to switch certain outputs on and off... i did that a while ago where the outputs drive relays, which switch fans on and off.
that thing looks really nice i love the effects that you have got with the plexiglass, but in my honest opinion you should tint the outside because firstly, you will still get all the effects that you are getting at the moment, secondly, the CD drive where its bolted on looks a bit ugly tbh, cos you can see the plastic it would hide that
blinking leds This is really a nice plexi case. I especially like the blinking led effects I have a question about them: Is it also possible to connect them to a serial part in stead of a parallel (lpt) port? I really want to use this effect in my case but I also want to have a lcd display hooked up to the lpt port. greetz, Joungne
