Project : HalfLife 2 - wavemaster : UPDATE:: 25/7/06
Discussion in 'Project Logs' started by Al_Cap0wnage, 9 Jul 2006.
  1. Al_Cap0wnage
    Al_Cap0wnage What's a Dremel?
    16 Jun 2006
    This is my first mod and as i dont have any experience i am starting it quite small with just painting, windows and lighting etc.. I got my wavemaster about 3 weeks ago am finally getting round to modding it :rock: ...
    Here is the only picture i have of it at the moment :worried:
    And here is what i plan to do to it (extremely rubbish drawing :D )
    The white HL2 logo is going to be a window (as you'd probably have guessed) and will be cut out with a dremel (when i get one :duh: )
    The window will be lit with 2 12" white cathodes and the front two led's will be changed from blue to white to match. I will probably change the HDD activity LED to white aswell.
    Anyway...
    I started by taking the case apart...
    here are all the bits:
    NOTE: PICTURES WILL BE OF A MUCH HIGHER QUALITY IN THE NEXT UPDATES...
    I am just going down to the garage to pick up some paint + high grit sand paper for wet sanding. Will i need primer? And do you think i should change anything in the idea?
    Cheers.
  2. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    No, I think it would look cool, if you can pull it off...... But maybe a bit ambitious if it's your first time with a dremel.:dremel:
  3. Al_Cap0wnage
    16 Jun 2006
    Yeah, but i suppose i am rather ambitious :D If i find it hard doing the logo i will probably not get round to doing the text along the bottom... Who knows though and thanks for the input.
  4. OldY
    OldY What's a Dremel?
    10 Mar 2006
    Great Idea!!! I love HL2 so this is brillient :thumb:
    To get the best finish with your paint, its best to have some primer first :)
    Good Luck :clap:
  5. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    The sketch looks great! Nice idea going white/orange. Only problem I can see is that the centre of the HL2 logo will have to be stuck to the window itself - probably not a problem actually.
    The lettering would look good cut-out, but if you are worried about it, you could always get it printed on white vinyl instead?
    I'm subscribing to this as your initial idea is so good. Keep us updated!
  6. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Read up on painting and it maybe easier to add a nice shape window and then add half life too with frosted decals maybe?
    Thats an expensive case, be careful mate!
    Good luck!
  7. Al_Cap0wnage
    16 Jun 2006
    I thought i might need primer, Thanks.
    Cheers, yup the actual centre of the logo and the 2 will have to be cut out with the spare from the inside of the main cut and stuck on the acrylic using some kind of strong glue. The vinyl idea sounds very good, but ill probably have a crack at cutting them anyway :D
    lol yep t'was rather expensive, you know of any good painting quides any were? thanks.
  8. Noni
    8 Dec 2005
  9. Noni
    8 Dec 2005
  10. Al_Cap0wnage
    16 Jun 2006
    Yeah but thats not orange :D , anyway painting it is part of the fun.
    Also i didnt but this case with the intention of modding it this way.
  11. Noni
    8 Dec 2005
    Ooooh yeah! Well good luck mate, theres a guy on [H]ardforum - http://www.hardforum.com/ Who paints Wavemasters. He has painted loads and maybe you could ask him for help, just put up a thread asking about that guy and about painting wavemasters and Im sure you will get loads of replys!
  12. Al_Cap0wnage
    16 Jun 2006
    cool, thanks alot for the link :)
  13. Lazlow
    8 Aug 2003
    By all means, give it a go! Try it on a scrap piece first (spare drive-bay bezel or something) and then you'll know if you can do it or not.
  14. Al_Cap0wnage
    16 Jun 2006
    I have an old aluminium side panel hanging around somewere so i will probably try it on that first.
    Anyway im off to get me some paints now so ill most probably have another update later.
  15. Lazlow
    8 Aug 2003
    Remember some wet/dry paper (for preparing and between coats) along with some clear coat/lacquer for finishing! You may also need some masking tape!
  16. Al_Cap0wnage
    16 Jun 2006
    Well i got to the shop just as the owner was leaving, but he kindly let me in :D
    I got 2 cans of orange, a can of primer and some 1000 grit to give the primer something to grip to.
  17. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    This mod is a great one, especially becuase its your first one you've done and its nice and simple and because its just a paint job, you don't have to worry about any drilling or cutting, which would complicate things etc etc...
    If you look at a few tutorials on spray painting and finishing it off to creat a really great finish it off... try this tutorial
    http://www.mnpctech.com/case-mod-paint-computer-pc-case-mod-how-to.html
  18. Al_Cap0wnage
    16 Jun 2006
    Thats a really good guide. Thanks.
  19. Noni
    8 Dec 2005
    Saw your thread on OCuk, you painted the sidepanel already? Wow fast work! Want to see more!
  20. Al_Cap0wnage
    16 Jun 2006
    lol yep only the primer though,
    side panel:
    door:
    Orange will be on later tonight...
    ... So more later. :D
