Project: Hangar 101 [Updated 4/2 *Final update - Final pics*]
Discussion in 'Project Logs' started by Sleepstreamer, 24 Jul 2006.
  1. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Oh wow, this mod is like freaking good sex so far. You don't want it to end! I love the eject button in the power button too :)
  2. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    The sides are in full action. Like everything else, they're made of 3mm Aluminium.
    I'm cutting out holes for the external HDDs that'll be peeking up on the sides.
    Yup, that's how I like it :rock:
    ... but I scrapped that idea, and cut a large hole instead... :duh: :D
    ...and slapped on a large piece of transparent acrylic (I know it is'nt showing on the images).
    A small cover-plate for the external HDD-ports, when they are'nt in use.
    The sides would be way too dull without any details. I thought of doing a a large etch over the entire acrylic. It ended with me making a small compromise :D [​IMG]
    ... and the other side of the window...
    The (so far) unbrushed result.
    Some engraving is about to be done. The image was made in photoshop.
    Almost done, looking good :)
    All done, and the result is a lot better then expected :rock: :hip: :D
    Damn, now I just have to do another one just like this :wallbash:
    //Sleepstreamer
  3. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    I like the HDD's poping out ;)
    Looks like ou got some skills at engraving, i'm guelous. I want a flexshaft! Hard to engrav without a shaft.
    EDIT:
    You can make your engraving look better if you use a grinding-bit after you engraved it ;)
  4. customh
    customh conflagration.
    22 Oct 2005
    Sweet, but i think an orange/ alu cover should be made for the drives.
  5. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Ya make like a peep hole dome for it so you can see it but it isn't open.
  6. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    I think what would be cool is instead, mount a sheet of plexi to the bottom of the HDD, and polish the front. It would fit in with the theme (assuming you polish the alu in the end... if not then brush the HDD cover...
    And, are you going to make the HDDs hot swappable? (SATA, and mounted connectors that the HDD slide into) cause that would give a nice reason to have them sticking out :)
  7. hydro_electric_655
    13 Jul 2006
    That would be sick swappable harddrives so you can just boot up computer to computer.
  8. Sleepstreamer
    23 Jul 2006
    As most of might have noticed, it's been a while... This is because I'm in the middle of my mandatory military education, and because of that I'm only at home in the weekends... It'll be some time between updates.
    The masking tape has been peeled of, and the metal has been brushed.
    A small "frame" made of 2.5mm aluminium has been fitted around the etching to gain some depth.Also, there is a polished mesh behind it (not sure if i'm going to use it)...
    The mesh. Polished, not chromed...
    The other side is done *phew*
    Next thing to be done is the top... See you in a while...
    //Sleepstreamer
  9. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    *Whistles*
  10. Muon
    Muon What's a Dremel?
    1 Dec 2004
    seeing it almost together...incredible. the workmanship and the way it works so well together, i'm in awe, pure awe.
  11. GT40_GearHead
    GT40_GearHead What's a Dremel?
    22 Jul 2006
  12. kbates666
    kbates666 What's a Dremel?
    24 Jan 2006
    Great Work, thanks for the update.
  13. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    does look good, in a way, but i personally dont like a case with that much - i dunno, glare factor ?
  14. customh
    22 Oct 2005
    lookin good i think!!
  15. davidbacsik
    davidbacsik What's a Dremel?
    23 Apr 2006
    Looks absolutely amazing. Crazy etching skills, by the way. The one thing that I would change is that I think on the drive side of the aluminum mounts for the etched plexi, I would remove the middle piece of aluminum. It's just a tiny bit too busy compared to the rest of the case.
    Again, awesome case.
  16. ViPPeR_666
    ViPPeR_666 What's a Dremel?
    31 Jul 2006
    I'm speechless! :rock:
    Damn you! :D
  17. xpc
    xpc What's a Dremel?
    26 Jul 2006
    lol. he's one of a hell damn modder. :D nice work bro!! very nice!!!
  18. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    This is "good-stuff"..
    Excellent work..
  19. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    I WANT YOUR CASE
  20. RadeX
    RadeX What's a Dremel?
    1 Sep 2004
    I must say that I don't know what to say :D
    PRO :rock:
