Case Mod - In Progress Project Ice Age
Discussion in 'Project Logs' started by Marcus V, 11 Jan 2015.
  1. montymole
    montymole Rigid Tubist
    24 May 2010
    looking really nice mate keep up the good work :)
  2. Marcus V
    Marcus V What's a Dremel?
    10 Jan 2015
    Thank you very much mate! I will surely :thumb:
  3. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    Looking good mate
    can't wait to see it with the watercooling :)
  4. Marcus V
    10 Jan 2015
    Thank you very much mate. Apriciate the backup! Cooling should come later this month :naughty:
  5. colinmcr
    colinmcr What's a Dremel?
    1 Jul 2014
    Very nice and clean looking
  6. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    Very nice. Is it easy to remove the mesh from the bottom to insert quad rad?
  7. Marcus V
    10 Jan 2015
    Thanks mate, that's the point :rock:
  8. Marcus V
    10 Jan 2015
    The mesh? The filter? Well it's easy to remove, but to installed/work in the bottom you just remove the side front panel and mount it :thumb:
  9. Marcus V
    10 Jan 2015
    New main sponsor just joined the project.
    Thanks to my friends over at Bitspower, Vincent, Roger, Lily.
  10. montymole
    24 May 2010
    Congrats on the Sponsorship really do love this
  11. Marcus V
    10 Jan 2015
    Thanks very much John! Waiting for the parcel :clap:
  12. stealth80
    stealth80 Minimodder
    1 Feb 2015
    I like the idea of flipping the Motherboard so you can see the GPU block, something that annoys me about most cases, that and the fact the window is always on the right had side, something that's driven me to move my build into a Thermaltake X9, which will also be coated white.
    Out of interest what fans are you using for the radiator ?
  13. Marcus V
    10 Jan 2015
    Thank you very much mate, I agree with you. Take an air cooled GPU, why look at the PCB at the top? Would be much cooler to look at the fans. And water cooled, you'll see the actually inside (if it's plexi)
    The fans are Corsair 120mm white led's :)
  14. Marcus V
    10 Jan 2015
    Thanks to Nanoxia for joining the project and sponsoring their PETG tubing
  15. Marcus V
    10 Jan 2015
    Thanks to Gavin from Bitfenix UK for sponsoring me fans and a fan controller, will come in later this week!
  16. Marcus V
    10 Jan 2015
    Thanks to Michael & Steve from Mayhems for joining this project
  17. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Need some updates c'mon! Keep up the good work ;)
  18. Marcus V
    10 Jan 2015
    Revived the PSU from Seasonic, I must say, the PSU is great, and has the Hybrid function so it's running fanless most of the time.
    Thank you very much Seasonic!​
