Scratch Build – In Progress Project Ice cube- Resources arrived
Discussion in 'Project Logs' started by Teknokid, 19 Dec 2007.
  1. ledbythereaper
    ledbythereaper What's a Dremel?
    2 Jan 2007
    I hope you know that with that case if you use the rad mounts in the roof you can't use any PCI cards... it blocks off a fair bit of the mobo..
  2. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    yeah, it does suck quite a lot, it will also be very tight with all the water gear i want, and seeing the quad rad today im not sure 2 will fit, hense the need for the new case :)
  3. La_mian
    La_mian What's a Dremel?
    26 Dec 2007
    Trust me,age is not problem.
    My first case I made is when I was 16.
    You don't need make it too perfect, just done it!
    OK? still have problem . add me.
    jasoncaoyuan@hotmail.com
  4. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    Cool, ill add you later, got any pics of yours?
  5. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    Little update:
    I put my pc in the case, i couldnt wait and ive gone ahead and got a quote for all the acrylic to build my own case.
    Below are some designs of side and front, ill try get some more, sorry if you cant see them too well....
    Cheeers
  6. marcus000
    marcus000 Watercooling Mad
    7 Aug 2007
    I'd spin the Hard drives round and route the SATA wires behind the mobo tray! :)
  7. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    So would i, but my sata cables are too short :(
    I've ordered new ones though :)
    what do you think of the designs (if you can understand them?)
  8. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    nice so far! keep it up
    looks like theres going to be a lot of fans
  9. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    yup just a few :)
  10. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    Damn that is a lot of fans, will be interesting to see this project, never seen a mod on this case before.
  11. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    i may not be modding the above case, i'm just sourcing my acrylic, which is looking good, in which case i will have my own custom build case :)
    keep a look out for this thread changing to project ice cube, ill let you know when i get a response for the acrylic
  12. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    the project hasnt started yet really, im still waiting for a quote on the acrylic, but heres how its looking now ( i tidied it up and added a fan for the hard disks):
    I cant wait to build my own case!!!
  13. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    The list
    Ok guys, heres the list of gear that i will eventually get once i've built my cube, ive already started saving/got some kit... Its not a full list, obv there is coolant, tubing, wormdrives etc needed:
    Item Price (ex VAT Price (inc VAT) Link
    Laing D5 £51.91 £60.99 http://www.aqua-pcs.co.uk/12v-laing-d5-vario-water-pump-12-barb-694-p.asp
    Laing DDC £42.00 £49.35 http://www.aqua-pcs.co.uk/12v-laing-ddc1-ultra-18w-696-p.asp
    Ek surpeme £29.78 £34.99 http://www.aqua-pcs.co.uk/ek-supreme-cpu-block-1113-p.asp
    NB block £20.96 £24.63 http://www.aqua-pcs.co.uk/ek-nbsb-s-max---acetal-1120-p.asp
    SB block £19.99 £23.49 http://www.aqua-pcs.co.uk/ek-nbsb-asus-3---acetal-1118-p.asp
    Mosfets £19.99 £23.49 http://www.aqua-pcs.co.uk/ek-mosfet-asus-3a-x38---acetal-1122-p.asp
    Blastflow VGA block £89.35 £104.99 http://www.aqua-pcs.co.uk/blastflow-siberian-modular-8800gtx-vga-block-1058-p.asp
    Mips ram freezer 4 £79.99 £93.99 http://www.vadim.co.uk/MIPS+RAM+Freezer+4
    Quad Rad £44.99 £52.86 http://www.aqua-pcs.co.uk/extreme-quad-120mm-radiator-1068-p.asp
    Ek res £27.75 £32.61 http://www.aqua-pcs.co.uk/ek-multioption-res-400-533-p.asp
    Sorry its a bad paste with duplications, its off excel, anyway, it comes to £756.81!!!
    Ill be saving for a little while it seems!!
    Just cant wait to get started on the build now.
  14. francisl1420
    francisl1420 What's a Dremel?
    23 Jul 2007
    Any idea how those quad rads comapre tothe thermochill PS120.3's?
  15. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    nope, im afriad not, but there bigger so that must count for something...
  16. ice-tea
    ice-tea Mr.PC-Max
    28 Apr 2006
    very very very big nonsense :nono:
  17. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    whys that?
  18. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    To mee this watercooling looks like absolute extreme overkill. Maybe the biggest I have seen yet.
  19. DeKemp
    DeKemp BEER.
    21 Feb 2007
    Why the heck would you want 3 loops 1 with a quad rad is nearing overkill for your system.
  20. Naberius
    20 Nov 2006
    3 Quad Rads! that has to be a first, what you planning on putting in each of the loops?
    At the moment i got a single 120.3 bix, that manages fine with an overclocked Q6600, dual 8800GTX and the chipsets, 3x 120.4's is a bit much.
